How to make that *.bat or *.exe file to work as background process?
Its not built from c or c++ codes.
Is there any software or are there any steps to follow?
I made that for you in the sample with C# NO NEED of that Batch file.
Itknowledge24.com
I have an executable file and i want it to run continuously with other system processes in the background.
Can u tell me how to do that?
Itknowledge24.com
Ya i know sir.
I just wanted to know is there anyway to make that .exe file to run internally other than the path.
U gave a path right what should i do with that. is there anyway to use the path to run this .exe file at the background?
Ya i know sir.
yes add the path to the Windows Registry with the paramter "-auto"
Itknowledge24.com
can i know what is windows registry?
From what I’ve read, the registry is data stored by Windows®,
configurations, and other important values. Now, all the registry
hives that you see using the ***Windows® Registry Editor (regedit)***are stored in files under the Windows® Directory.
However, to give you better information I suggest you read the following
Microsoft® Support KB: http://support.microsoft.com/kb/256986
Also, to try out yourself, just press
+ R and type*“regedit”* and press
Enter.
Security note: If UAC is enabled, then you’ll get a UAC prompt on screen. Please
specify
credentials or permission to pass the UAC elevation.
I hope you find this information useful. If you need any further assistance,
please feel free to contact me and let me know.
I hope this information was helpful…
Have a nice day…
Best regards,
Fisnik
Itknowledge24.com
