How to run an executable internally along with other background processes in the system during the startup?
2010-07-30T03:39:55+00:00
I have an executable file and i want it to run continuously with other system processes in the background.
Can u tell me how to do that?
    2010-08-02T17:03:07+00:00
    The truth is they just give tthe ideas and i dont find any teacher who is well versed in the subject as i see in you sir.
    Am trying to know everything on my own with the help of you guys.
    Can u suggest me what can i start with?
    Many companies are coming to our college this month for the placements and i have to be ready with a project of my own.
    2010-08-02T17:03:26+00:00
    2010-08-02T17:04:48+00:00
    To be able to write code for each button, you
    select the button and right-click and then select
    Properties, and then from the Properties panel
    select Event category and add the event for
    mouse_click or button_click and then inside
    that event add the code. It is complicated
    first TIME.
    Itknowledge24.com
    But what code should i write?
    2010-08-02T17:04:52+00:00
    I see, please do NOT double-POST.
    Itknowledge24.com
    2010-08-02T17:06:17+00:00
    first TIME.
    Itknowledge24.com
    Think again, and try again, my suggestiong, use the Class which I made for you.
    Itknowledge24.com
