How to run an executable internally along with other background processes in the system during the startup?
2010-07-30T03:39:55+00:00
I have an executable file and i want it to run continuously with other system processes in the background.
Can u tell me how to do that?
    2010-08-02T16:51:39+00:00
    Okey thanks fisnik.
    I am lucky to get a chance of speaking to an expert and getting his suggestions.
    I am definitely trying hard but many a times i am not able to understand the coes written by other programmers as am not that perfect.
    For example i thought to create a media player so i searched in google where i can get a simple code to create media player and it contained many new things which i couldnt understand kile HWND etc,.,
    There are different windows defined datatypes.
    Anyways am trying to understand those things.
    2010-08-02T16:54:06+00:00
    I just learned to creae a simple dialogue box where i inserted 2 buttons and a text showing the message.
    Now i have to write a code to each button right?
    If the user clicks yes then what to do if NO button then what to do.
    How to do that?
    2010-08-02T16:58:19+00:00
    Okey thanks fisnik.
    Yes, but don't you see the problem. The ability to understand
    and grow, shall NOT start with BIG advanced projects, build
    something like Windows Media Player is very hard if you
    are a beginner in programming. Also if you do NOT understand the
    entire code, you should look for /* comments */
          <-- Comments.
    // <-- Comments.
    Programmers use comments to explain their code to other programmers/developers.
    My best advice, if YOU REALLY WANT to understand things perfectly,
    ask the correct questions, and the correct question are those which
    you want to be answered, like "Sir what does this line of code mean and do?".
    Also my BEST advice would be that you ask your programmer teacher regarding code
    which you DO NOT understand, and TRUST me the teacher can explain it much better
    then what I do, unless I have reached the same level of skills.
    Itknowledge24.com
    2010-08-02T17:02:24+00:00
    How to do that?
    To be able to write code for each button, you
    select the button and right-click and then select
    Properties, and then from the Properties panel
    select Event category and add the event for
    mouse_click or button_click and then inside
    that event add the code. It is complicated
    first TIME.
    Itknowledge24.com
    2010-08-02T17:03:00+00:00
    The truth is they just give tthe ideas and i dont find any teacher who is well versed in the subject as i see in you sir.
    Am trying to know everything on my own with the help of you guys.
    Can u suggest me what can i start with?
    Many companies are coming to our college this month for the placements and i have to be ready with a project of my own.
