All your websites are under construction.
When will it get finished?
I have an executable file and i want it to run continuously with other system processes in the background.
Can u tell me how to do that?
Thanks for giving the information.
I guess after submitting the report many will be posting their messages to you from our college.
Hope you can help them too:)
Not sure, I cannot help everybody with their "school" work, directly,
however, I can give advice and (directions in VS2010), but NOT do
the coding "UNLESS THEY HAVE TRIED HARD AND FAILED MANY TIMES",
then they are free to post their issue and let me check their source code. :)
Because you MUST understand that the "GRADE" which you get on the work
isn't the MOST important, what's IMPORTANT is the experience, the knowledge
and that you can see the differences, you can write code from scratch you can
fix bugs and find and fix code syntax errors and that you have the knowledge
to write software documentation and provide good information about
your software project to your manager.
If you want to work as a programmer in the future please keep in mind thatyou MUST know this:*Programming Basics and Advanced level. *Good knowledge and good skills. *The ability to write documentation for projects and software releases. *The ability to understand code written by other programmers/developersin your group or team. *The ability to expand the knowledge and try new things, it will be a challenge.
Those are some to mention, but keep it up and learn more.
Itknowledge24.com
Some weeks left, however, I have free software tools
and PDFs.
Itknowledge24.com
And one more thing.
You dint tell me how to proceed?
I have posted the image above:)
Wait, I was replying the above POST.
Itknowledge24.com
And one more thing.
What do you want to have in that FORM?
Itknowledge24.com
