Here they are: Instructions. 1. StartMicrosoft® Visual Studio® 2010 IDE .
2. From the Start Page selectNew Project link.
3. Under Installed Templates selectVisual C++.
4. Select MFC Application .
5. Provide application (project) name and click OK .
Note: A MFC Application Wizard will appear on screen.
6. Click Next .
7. Under Application type selectDialog based , and
under Resource language select
“English (United States)”
(or your country), leave the “Use Unicode libraries” and
for the Project style leave the (default)
MFC standard and
for the Use of MFC select Use MFC in a shared DLL , and
click Next .
8. Set the Main frame style as follows:
*Thick frame *Minimize box *About box*Please remove SYSTEM menu.
Click Next .
9. For the Advanced features uncheck“Context-sensitive Help (HTML)”
and ActiveX controls . You shall only useCommon Control Manifest
and Support Restart Manager , and then click Next .
10. Click Finish .
I hope you find this information useful. If you need any further assistance,
please feel free to contact me and let me know.
I hope this information was helpful…
Have a nice day…
Best regards,
Fisnik
Itknowledge24.com
Thank you sir i will try now and ask if i get stuck:)
