How to run an executable internally along with other background processes in the system during the startup?
2010-07-30T03:39:55+00:00
I have an executable file and i want it to run continuously with other system processes in the background.
Can u tell me how to do that?
    2010-07-31T04:06:05+00:00
    How to make that *.bat or *.exe file to work as background process?
    Its not built from c or c++ codes.
    Is there any software or are there any steps to follow?
    2010-07-30T21:37:53+00:00
    Sorry I don't understand this question. Please clarify exactly what
    you want to do.
    And what is this "executable file"? What is its name? What does it do?
    Ken Blake
    It is a *.batch file which he converted, you might need to follow his first post
    in order for you to fully understand the OP's issue. Ken, check the OP's first
    POST on this forum, it is a programming challange he wants to produce
    software under Windows Environment using Microsoft Visual Studio 2010,
    currently I've been helping him.
    Itknowledge24.com
    2010-07-30T20:04:33+00:00
    you want to do.
    Ken Blake
    2010-07-30T11:05:30+00:00
    If it is an executable file which was converted from batch file then how to put the path?
    There is no program for it. Only one command.
    Is there any other method to make it work at background?
    2010-07-30T07:58:03+00:00
    Hi Abhilash:
    You must put the path to the program in a String_REG value
    in Windows® Registry under the following path:
    *HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Run*
    I hope you find this information useful. If you need any further assistance,
    please feel free to contact me and let me know.
    I hope this information was helpful…
    Have a nice day…
    Best regards,
    Fisnik
    Itknowledge24.com
