Setting default line spacing in Wordpad
2010-05-09T11:36:35+00:00
I have noticed an extremely annoying trait in the Windows 7 version of Word Pad. The Default line spacingis set to 1.15 and "add 10pt after paragraphs".
I would like to change the Default line spacing to 1.0 and "No 10 pt space after paragraphs".  is this possible with a registry hack?
I realize this is silly, but it really is annoying.
Any Input is very much appreciated,
Paul
2011-11-10T08:14:56+00:00
I found a really simple trick to bypass this really annoying trait.
I create a simple Wordpad document with the desired settings I want (including fixing the spacing).
I then delete every character, save one ( If you delete the last one Wordpad will default back to
Cambria - 11pt).
Now save this document as 'Document.rtf' or whatever name you want and to any directory you want.
Create a shortcut on your desktop to this file.  Then rename the shortcut Wordpad.
Now whenever you open Wordpad thru this link you will have it open and ready to go with all your settings!
There will be of course one character there, but I start all my Wordpad encounters with copying & pasting
so I never notice it.
I realize this fix might not be what everyone wants, but for anyone who just opens Wordpad from their
desktop like me and many others it is a extremely simple fix to a most annoying problem.
2010-05-10T00:46:16+00:00
I am afraid t o inform that this is by design in Windows 7 and you will not be able to change it.
Thanks and Regards:
Shekhar S - Microsoft Support. Visit our Microsoft Answers Feedback Forum and let us know what you think.
If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
64 additional answers
    2012-08-13T07:06:54+00:00
    The fix is actually quite simple (if you don't mind getting your fingers dirty). The settings might be baked into wordpad (silly thing to do), but the templates-system is still there.
    1. Create a template file called "New Rich Text Document.rtf " (or whatever you want the default filename to be) in *C:\Windows\ShellNew* , edit this file to your desired settings. Don't forget to save.
    2. Open regedit, browse to HKEY_CLASSES_ROOT.rtf\ShellNew and add a new string (New -> String Value) calledFileName . Choose Modify and set Value data to "New Rich Text Document.rtf ". (or whatever your template is called)****
    Or you can paste the following into a pure text-file named rtf.reg. Remember to create the template...
    Windows Registry Editor Version 5.00[HKEY_CLASSES_ROOT.rtf\ShellNew]"FileName"="New Rich Text Document.rtf"
    I tried that but somehow the registry won't change with the .reg file... (myth)
    But anyway I think that only fixes a create new file with mouse right click.
    I call out word pad 99% time from run command>>write, it it just annoying that it spaces out so much.
    Such a retarded "new" feature
    I am with you R e i... Although i learned something from Fulmen's post, it doesn't help because i call wordpad from Win+R>>wordpad, bummer because i like a lot of the wordpad features compared to notepad. Also, wordpad is much faster than msword and swriter. I will keep looking for a solution even if it means getting my fingers very dirty!
    2012-08-13T12:52:54+00:00
    I rebooted my windows 7 this morning and was back to double spacing again.  I clicked on the upper left line icon but could not get the checkmark out of the box to turn off the double spacing.  i clicked ctrl+1 but it did not work.  Now I can't find Andy
    Ottoman's explaination which worked the first time even though I thought I bookmarked it.
    Peter Fricano
    2012-08-13T16:30:51+00:00
    I am happy with my fix.  Here 'tis again (thought I posted this but can't seem to find it...) :
    1. Open WordPad
    2. Change linespacing options - uncheck Add 10pt space after paragraphs
    3. and ... I change spacing to 1.0
    4. type one space
    5. I also change font to what I prefer
    6. Save the file as a template - anywhere you like
    7. Find that file - right-click on it and go into Properties
    8. I check both Readonly and Hidden
    9. Create a shortcut - I use WordPad so much I prefer to Pin it on the Taskbar area
    10. Right-click on the shortcut - add the file to the Target string - here's mine:  "%ProgramFiles%\Windows NT\Accessories\wordpad.exe" "F:\My Documents\Blank Document RO.rtf"
    So now when I click on the shortcut,
    • the canned blank document opens
    • with my chosen spacing
    • with my chosen font & font size
    • and at the very top of the document, in front of that space - so it doesn't start in column 2
    If by some usual occurrence, I try to save the file without doing Save As, WordPad automatically defaults to Save As because it won't overwrite the readonly template I've created.
    Not the way I'd prefer to do it but Msoft is too smart (see "sarcasm") to let me change their default.
    Bardy
    Baltimore MD
