Setting default line spacing in Wordpad
2010-05-09T11:36:35+00:00
I have noticed an extremely annoying trait in the Windows 7 version of Word Pad. The Default line spacingis set to 1.15 and "add 10pt after paragraphs".
I would like to change the Default line spacing to 1.0 and "No 10 pt space after paragraphs".  is this possible with a registry hack?
I realize this is silly, but it really is annoying.
Any Input is very much appreciated,
Paul
2011-11-10T08:14:56+00:00
I found a really simple trick to bypass this really annoying trait.
I create a simple Wordpad document with the desired settings I want (including fixing the spacing).
I then delete every character, save one ( If you delete the last one Wordpad will default back to
Cambria - 11pt).
Now save this document as 'Document.rtf' or whatever name you want and to any directory you want.
Create a shortcut on your desktop to this file.  Then rename the shortcut Wordpad.
Now whenever you open Wordpad thru this link you will have it open and ready to go with all your settings!
There will be of course one character there, but I start all my Wordpad encounters with copying & pasting
so I never notice it.
I realize this fix might not be what everyone wants, but for anyone who just opens Wordpad from their
desktop like me and many others it is a extremely simple fix to a most annoying problem.
2010-05-10T00:46:16+00:00
I am afraid t o inform that this is by design in Windows 7 and you will not be able to change it.
Thanks and Regards:
Shekhar S - Microsoft Support. Visit our Microsoft Answers Feedback Forum and let us know what you think.
If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.
64 additional answers
  1. Deleted
    2011-07-26T22:33:58+00:00
    Here is a small program that fixes the issue
    www.holdkey.eu/wordpadfix.php
  3. Deleted
