Removing foreign language fonts
2009-10-30T16:13:49+00:00
Does anyone know of a way to remove the many foreign language fonts from Windows 7? There wasn't an option to exclude them during setup. I've tried deleting them, but Windows tells me that they are system fonts which cannot be deleted. I've also tried "Hiding" them, but they still show up in the font list in Office and other programs. All I want and need are the basic English language fonts. Having to wade through dozens of useless (to me) fonts is a major annoyance. There should be a way to exclude them from my system if I don't need them.
2009-12-05T14:33:12+00:00
Hello mcbarker69,
The reason that I did not know the fonts in question is because no particular fonts were mentioned, and I had gone into fonts and removed a couple foreign fonts with no problem. However that being said, in order to remove the fonts that are being referred to follow these steps:
Take ownership of the file:
 - Click Start Orb > type fonts in the search box > click Fonts
 - Right-click the font > click Properties - Click Security tab > click Advanced - Click Owner > click Edit - Select your Username > click OK
Click OK on the Windows Security box
Change Permissions of the file:
 - Click Permissions > click Change Permissions
 - Select your Username > click Edit
 - Checkmark Allow for Full control
 - Click OK - Click OK
Click Yes on the Windows Security box
 - Click OK
You will need to remember the names of your font(s) that you want to delete.
Delete the file:
Will need to start Safe mode with command prompt
Restart your computer and tap F-8 continually, this will bring you to your Advanced Boot Options, select Safe mode with command prompt.
Once you have booted:
In command prompt navigate to fonts:
 - type cd c:\windows\fonts > press enter
 - type del "font name" > press enter *Do not use the quotes around the font name
This should bring you back to a clean prompt.
Once you are finished > Ctrl+Alt+Del > select restart from the arrow in the bottom right corner of your screen and start Windows normally.
Hope this helps
As the Windows Security box states; this could cause Windows to act differently. Make sure you know which fonts you are removing and that Windows does not need them before you remove any protected system fonts. This could cause many complications with your installation of Windows.
Chris.H
133 additional answers
    2010-02-07T13:13:46+00:00
    Hi Bryan. Thanks for the helpful link. It's a big step forward, but it leaves me a bit baffled.
    For example, it tells me Andalus contains Unicode ranges Basic Latin, Latin-1 Supplement, Arabic, Arabic Presentation Forms-A, Arabic Presentation Forms-B.
    So it looks like Andalus is intended mainly for Arabic. But it contains a Latin alphabet as well.
    Then it shows Arial contains Unicode ranges (deep breath) Basic Latin, Latin-1 Supplement, Latin Extended-A, Latin Extended-B, IPA Extensions, Spacing Modifier Letters, Combining Diacritical Marks, Greek and Coptic, Cyrillic, Cyrillic Supplementary, Hebrew, Arabic, Latin Extended Additional, Greek Extended, General Punctuation, Superscripts And Subscripts, Currency Symbols, Mathematical Operators, Supplemental Mathematical Operators, Miscellaneous Mathematical Symbols-A, Miscellaneous Mathematical Symbols-B, Box Drawing, Block Elements, Geometric Shapes, Miscellaneous Symbols, Alphabetic Presentation Forms, Arabic Presentation Forms-A, Combining Half Mar.
    WOW! So Arial now contains just about every alphabet that's possible in Unicode.
    The trouble is, it doesn't give me a good steer as to which fonts aren't necessary. If I deleted all fonts that supported arabic, I'd end up deleting Arial and that would be crazy.
    The key issue seems to be this. Andalus, for example, is intended mainly for Arabic. However, for general usability it also contains an additional Latin alphabet. Therefore, I could use it for plain English writing. However, that would be a really bad idea. Since the Latin alphabet is a sort of extra feature the Latin characters may be of poorer quality, or may turn out to be identical to another font I already have under a different name. There would certainly be problems if I sent my document written in Andalus to another user who didn't have that font. They would have all the hassle of getting the font I'd specified, only to find out that it gave them no benefit over some other font that we both had.
    I still think it would be helpful to have some advice from Microsoft along the lines ...
    "If you're writing in English you don't need fonts xxx, yyy, and zzz."
    And ...
    "Never try to delete fonts ppp, qqq, rrr, and sss. If you do Windows will stop working."
    2010-02-11T13:27:19+00:00
    Hi guys,
    I think I found an easy way to get rid of those unwanted fonts. I am not sure if this will work on another machine because I messed around with the fonts a lot, even with Linux Fedora. So maybe something changed (see the *** paragraph in my answer below), but now I can easily remove the fonts with a batch file.
    Besides from the obviuous advantage of my batch file, removing the fonts "in a batch", is that the batch filemoves the font-files to another folder instead of completely deleting them. That way, you can later browse that backup folder and reinstall any fonts you might need.
    The batch files moves150 149 (!) font-files, which doesn't mean150 149 fonts, as some fonts are build as a font family which contains several *.ttf files, most times 4 files: regular, bold, italic, bold-italic.
    Someone out there brave enough to test my batch file? Then please keep in mind  that I tested this on aGerman Windows 7 Ultimate system and that things might be different (named) in your (English) Windows, and accept thatI am not responsible if you mess up your Windows - but I think and hope it works out fine. Now here you go:
    The following instructions and explanations are not up to date anymore , please read my post from March 15 below!
    • First, create a new folder "2manyfonts" on the same drive/partition where your Windows folder is located. In my case, I have C:\Windows, the fonts are in C:\Windows\Fonts, and I created C:\2manyfonts
    • Download my batch file_2mf.bat(or the zipped file ) and put it into your 2manyfonts folder (you created that folder, right?)
    • Click theStart Orb(aka Start button ;-) ) and typecmd in the search box
    • In the list above right-click oncmd.exeand choose Run as administrator
    • In the command window, type "cd \2manyfonts" without the quotes
    • Type "_2mf.bat X" and replace the X by the letter of your Windows partition, inmy case C, so I typed "_2mf.bat C", put a space before the drive letter
    • Press Return/Enter
    • When the batch is finished, which should just take a second, you should have 150 *.ttf files in your 2manyfiles folder.
    • Please don't close the command window yet, but you can browse the folder in the Explorer if you want. Interestingly the font symbols now show latin letters…
    If the batch file movedsome , but not all149 fonts for you, please type "dir /b > fontlist.txt" in the command window, this will create a list of all fonts in the 2manyfonts folder and post this list here or as a comment in my related blog articleHow to remove Windows 7 non-latin fontsso I can see which fonts wereprotected.
    If you think I put too many or too less fonts in my moving list, please let me know which one(s).
    *** As I said, I messed around with Linux on my system and created a Linux script that I used to move the fontsbeforeI tested the Windows batch file. Maybe the Windows batch file now works on my system just because Linux changed something, e.g. the ownership of the files.
    In the latter case, there are still possibilities to move those fonts.
    Best way is with a Live-CD, either a Linux or a Windows one, BartPE, VistaPE  or Windows PE to name a few. I can provide a documentation for that, too.
    Or you could connect your Windows 7 harddrive to another computer or boot a parallel Windows on the same drive, if you have one, and start the batch file, in that case with different drive letters of course.
    Regards
    Martin Ihde
    Freelancer for IT-support and webdesign
    Support-Ing
    2010-02-11T16:12:59+00:00
    I'm also completely frustrated and aggravated by this problem. I won't repeat what everyone else has said, although I would dearly love to vent. Not being as technically knowledgeable as some other posters here, I'm not going to try Martin Ihde's fix until someone else does.
    I have one question about it: where are the deleted (moved) fonts listed? Are they in the batch file? What if you want to keep the non-Roman fonts for a specific language but get rid of the rest? I can use Hebrew; at least one other poster has mentioned that s/he could use Chinese.
    Also, I came up with an idea that is not too elegant but would at least cut down on the frustration of the long font list. I thought of renaming the unwanted font files by prefixing each of them with "zz": e.g., Aparajita would become zzAparajita. This would at least move them all down to the bottom of the list. Unfortunately, when I tried this I found that the Rename option for these files is grayed out. Perhaps someone here can figure out how to do this?
    And what's with all the fonts that start with @? Most of them appear to be non-Roman fonts that I have set to "hide," but other "hidden" fonts appear in the alphabetical listing.
    I'm running Home Premium, US edition.
    2010-02-11T20:20:05+00:00
    Hi askf,
    it's not that big a deal, actually. At least not if you have ever used the command window. What the batch file generally does is to move font-file by font-file to that folder 2manyfonts. The command for that reads as follows:
       move %windrive%:\Windows\Fonts\aparaj.ttf %windrive%:\2manyfonts\aparaj.ttf
    The %windrive% is a variable, which holds the drive letter, in my example "C". So once you start the batch file with the command "_2mf.bat C " the command executed by the batch files reads:
       move C:\Windows\Fonts\aparaj.ttf C:\2manyfonts\aparaj.ttf
    The command should be clear, then comes the source-folder\file and then the target-folder\file. "aparaj.ttf " is the font-file to be moved, but this is not what the Explorer  or the Font-Administration shows you when you open the C:\Windows\Fonts folder, it shows you Aparajita .
    You can test this when you open a command window. No need for "Run as administrator" this time, just typecmdin the search box and press Enter, then type dir c:\windows\fonts /p and press Enter again. This will just list you the content of your fonts folder, page by page. Press either any key for the next page or CTRL+C if you have seen enough.
    As the font list to be moved is quite long, I don't want to list it here, but I have added a list in myblog article .
    For the fonts you or someone else would like to keep there are two ways, either remove those files from the batch file, or install them again after they have been moved. You can reinstall them when you open the C:\2manyfonts folder in your Explorer and mark all files you want to reinstall and right-click them and choose "install".
    I don't have any fonts starting with @, so I am not sure which one you are mentioning.
