Removing foreign language fonts
2009-10-30T16:13:49+00:00
Does anyone know of a way to remove the many foreign language fonts from Windows 7? There wasn't an option to exclude them during setup. I've tried deleting them, but Windows tells me that they are system fonts which cannot be deleted. I've also tried "Hiding" them, but they still show up in the font list in Office and other programs. All I want and need are the basic English language fonts. Having to wade through dozens of useless (to me) fonts is a major annoyance. There should be a way to exclude them from my system if I don't need them.
2009-12-05T14:33:12+00:00
Hello mcbarker69,
The reason that I did not know the fonts in question is because no particular fonts were mentioned, and I had gone into fonts and removed a couple foreign fonts with no problem. However that being said, in order to remove the fonts that are being referred to follow these steps:
Take ownership of the file:
 - Click Start Orb > type fonts in the search box > click Fonts
 - Right-click the font > click Properties - Click Security tab > click Advanced - Click Owner > click Edit - Select your Username > click OK
Click OK on the Windows Security box
Change Permissions of the file:
 - Click Permissions > click Change Permissions
 - Select your Username > click Edit
 - Checkmark Allow for Full control
 - Click OK - Click OK
Click Yes on the Windows Security box
 - Click OK
You will need to remember the names of your font(s) that you want to delete.
Delete the file:
Will need to start Safe mode with command prompt
Restart your computer and tap F-8 continually, this will bring you to your Advanced Boot Options, select Safe mode with command prompt.
Once you have booted:
In command prompt navigate to fonts:
 - type cd c:\windows\fonts > press enter
 - type del "font name" > press enter *Do not use the quotes around the font name
This should bring you back to a clean prompt.
Once you are finished > Ctrl+Alt+Del > select restart from the arrow in the bottom right corner of your screen and start Windows normally.
Hope this helps
As the Windows Security box states; this could cause Windows to act differently. Make sure you know which fonts you are removing and that Windows does not need them before you remove any protected system fonts. This could cause many complications with your installation of Windows.
Chris.H
133 additional answers
    2015-12-03T01:21:44+00:00
    I've been a member of this forum for years and if I never learned another thing it's that Microsoft apparently doesn't listen to anyone. This has been a burning flaw with Microsoft for years and there are many, many of us users all of whom have sought out every possible assistance or solution (that doesn't exist). I am moving on and one day perhaps will be pleasantly surprised that some kind soul in Microsoft finally got it and decided to share the secret with us all.
    2015-12-03T01:47:33+00:00
    I luuuuuv all the techie talk about this annoyance! But if you're like me (i.e. not a computer geek at all), you'll appreciate this spectacularly simple fix for the Foreign Font Scourge problem.
    Just de-register the unwanted fonts & families.
    1. run regedit.exe
    2. Navigate to
        HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Fonts
    1. Delete the font names you don't want.
    Note that this proc does not remove the fonts from your PC. It just hides them from Windows so they won't clutter up your font lists.
    I found this fix here:
    <http://www.wikihow.com/Delete-Protected-System-Fonts-in-Windows-7>
    2016-02-16T19:09:26+00:00
    I followed the instructions verbatim and as an administrator. The batch file ran and in the process repeated many times the following to the screen:
    'icacls' is not recognized as an operable program or batch file.
    0 files moved and
    Access is denied and
    The system cannot find the specified files.
    When it was all done no font files were residing in the c:\2manyfonts directory and the fonts I wanted rid of are still listed in FONTS, and I looked in your batch file and you are indeed targeting  the fonts I wanted rid of. I don't know who presumed I'd ever need those, but most of my applications list them making my list of fonts way to long. I'm slightly acquainted with batch files but not ICACLS and that seems to be one of the glitches on my machine (Windows 7 x64)
    I directed/piped the output of the batch file that normally goes  to the screen to a TXT file with the following results:
    BEGIN END BATCH FILE WRITES TO SCREEN
    C:\2ManyFonts>REM This is the batch file _2mf.bat version 1.0 from 2010-03-15
    C:\2ManyFonts>REM This batch file which will move 150 non-latin fonts
    C:\2ManyFonts>REM from the Windows\Fonts directory to a backup directory
    C:\2ManyFonts>REM Please read the readme.txt for more information
    C:\2ManyFonts>REM Latest version and news can be found in the blog-post
    C:\2ManyFonts>REM "How to remove Windows 7 non-latin fonts" on
    C:\2ManyFonts>REM http://www.support-ing.de/2010-02-11/how-to-remove-windows-7-not-latin-fonts
    C:\2ManyFonts>REM
    C:\2ManyFonts>REM Use on your own risk
    C:\2ManyFonts>REM
    C:\2ManyFonts>REM Written by Support-Ing Martin Ihde, http://www.support-ing.de
    C:\2ManyFonts>REM
    Fonts will be moved from c:\Windows\Fonts\ to c:\2manyfonts\
    Continue? Please press "y" for yes or "n" for no:          0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
            0 file(s) moved.
    Finished!  :-)
    Press any key to continue . . .
    This bat file was run in c:\2manyfonts  and the path in that place was as follows:
    PATH=C:\ProgramData\Oracle\Java\javapath;C:\PROGRAM FILES\COMMON FILES\MICROSOFT SHARED\WINDOWS LIVE;C:\PROGRAM FILES (X86)\COMMON FILES\MICROSOFT SHARED\WINDOWS LIVE;C:\PROGRAM FILES (X86)\INTEL\ICLS CLIENT;C:\PROGRAM FILES\INTEL\ICLS CLIENT;C:\PROGRAM FILES (X86)\ATI TECHNOLOGIES\ATI.ACE\CORE-STATIC;C:\WINDOWS\COMMAND;C:\Windows;C:\PROGRAM FILES (X86)\AMD\ATI.ACE\CORE-STATIC;;C:\Program Files\Lenovo\Bluetooth Software;C:\Program Files\Lenovo\Bluetooth Software\syswow64;C:\Program Files (x86)\Common Files\Seagate\SnapAPI;C:\Program Files (x86)\QuickTime\QTSystem\
    I don't know if 'icacls' is an OS internal or batch internal command I'm unfamiliar with, or if it was an executable assumed to be in my path and wasnt?
    Any tips on what I missed to make this valuable and time saving batch run are welcomed. Thanks, Dean
    ******@cox.net 2/16/16
    2016-02-27T03:38:40+00:00
    So MS Support acknowledged these bugs way back in 2010 and it's now 2016 and nothing has been done to fix them? I'm not a techie person, but I'm learning Linux. MS is full of these insane bugs that make it through upgrade after upgrade (STILL can't rename a folder that you've just modified either).
