Removing foreign language fonts
2009-10-30T16:13:49+00:00
Does anyone know of a way to remove the many foreign language fonts from Windows 7? There wasn't an option to exclude them during setup. I've tried deleting them, but Windows tells me that they are system fonts which cannot be deleted. I've also tried "Hiding" them, but they still show up in the font list in Office and other programs. All I want and need are the basic English language fonts. Having to wade through dozens of useless (to me) fonts is a major annoyance. There should be a way to exclude them from my system if I don't need them.
2009-12-05T14:33:12+00:00
Hello mcbarker69,
The reason that I did not know the fonts in question is because no particular fonts were mentioned, and I had gone into fonts and removed a couple foreign fonts with no problem. However that being said, in order to remove the fonts that are being referred to follow these steps:
Take ownership of the file:
 - Click Start Orb > type fonts in the search box > click Fonts
 - Right-click the font > click Properties - Click Security tab > click Advanced - Click Owner > click Edit - Select your Username > click OK
Click OK on the Windows Security box
Change Permissions of the file:
 - Click Permissions > click Change Permissions
 - Select your Username > click Edit
 - Checkmark Allow for Full control
 - Click OK - Click OK
Click Yes on the Windows Security box
 - Click OK
You will need to remember the names of your font(s) that you want to delete.
Delete the file:
Will need to start Safe mode with command prompt
Restart your computer and tap F-8 continually, this will bring you to your Advanced Boot Options, select Safe mode with command prompt.
Once you have booted:
In command prompt navigate to fonts:
 - type cd c:\windows\fonts > press enter
 - type del "font name" > press enter *Do not use the quotes around the font name
This should bring you back to a clean prompt.
Once you are finished > Ctrl+Alt+Del > select restart from the arrow in the bottom right corner of your screen and start Windows normally.
Hope this helps
As the Windows Security box states; this could cause Windows to act differently. Make sure you know which fonts you are removing and that Windows does not need them before you remove any protected system fonts. This could cause many complications with your installation of Windows.
Chris.H
133 additional answers
    2015-11-29T14:23:48+00:00
    this is way too complicated. Why can't there be an easier way for goodness sake to delete these unwanted fonts
    2015-11-29T18:42:29+00:00
    Ya, this procedure sucks. this is insane. I DESPISE these fonts which destroy my ease of use in Photoshop as well as in windows. I actually went through this week-long procedure a couple years ago and then - when they upgraded me to windows 8, GUESS WHAT HAPPENED!!!!!   A fact worth mentioning, Chris H!
    2015-11-30T00:15:00+00:00
    Chris: "GUESS WHAT HAPPENED!!!!!"
    Don't keep us in suspense!  What happened?
    2015-11-30T04:15:11+00:00
    Sorry JJ, i thought it was obvious but it most certainly is NOT obvious:
    all the fonts I worked for days to remove, they all reappeared as soon as I was upgraded to windows 8.
    so, it's completely futile to try to remove these as we all are forced to upgrade regularly. My heart sank.
    tragedy.
    take care.
    carol
