Removing foreign language fonts
2009-10-30T16:13:49+00:00
Does anyone know of a way to remove the many foreign language fonts from Windows 7? There wasn't an option to exclude them during setup. I've tried deleting them, but Windows tells me that they are system fonts which cannot be deleted. I've also tried "Hiding" them, but they still show up in the font list in Office and other programs. All I want and need are the basic English language fonts. Having to wade through dozens of useless (to me) fonts is a major annoyance. There should be a way to exclude them from my system if I don't need them.
2009-12-05T14:33:12+00:00
Hello mcbarker69,
The reason that I did not know the fonts in question is because no particular fonts were mentioned, and I had gone into fonts and removed a couple foreign fonts with no problem. However that being said, in order to remove the fonts that are being referred to follow these steps:
Take ownership of the file:
 - Click Start Orb > type fonts in the search box > click Fonts
 - Right-click the font > click Properties - Click Security tab > click Advanced - Click Owner > click Edit - Select your Username > click OK
Click OK on the Windows Security box
Change Permissions of the file:
 - Click Permissions > click Change Permissions
 - Select your Username > click Edit
 - Checkmark Allow for Full control
 - Click OK - Click OK
Click Yes on the Windows Security box
 - Click OK
You will need to remember the names of your font(s) that you want to delete.
Delete the file:
Will need to start Safe mode with command prompt
Restart your computer and tap F-8 continually, this will bring you to your Advanced Boot Options, select Safe mode with command prompt.
Once you have booted:
In command prompt navigate to fonts:
 - type cd c:\windows\fonts > press enter
 - type del "font name" > press enter *Do not use the quotes around the font name
This should bring you back to a clean prompt.
Once you are finished > Ctrl+Alt+Del > select restart from the arrow in the bottom right corner of your screen and start Windows normally.
Hope this helps
As the Windows Security box states; this could cause Windows to act differently. Make sure you know which fonts you are removing and that Windows does not need them before you remove any protected system fonts. This could cause many complications with your installation of Windows.
Chris.H
133 additional answers
    2013-01-17T02:04:39+00:00
    How can I get a list of all System Fonts, that should NOT be deleted?
    2013-01-17T02:49:39+00:00
    Thanks, It sure is worth a try.
    But I want to clarify: I am referring to fonts installed by Word and not Windows Fonts. I have already deleted all the Windows font bloat.
    Doesn't Word prompt for the ZZ fonts when you open a document?
    2013-01-19T00:58:19+00:00
    My first reply was actually supposed to be addressed to anyone trying to hide any foreign language or other fonts listed in the Windows font folder.
    When I install Word 2000 from disk 1 of my Microsoft Office 2000, there are no fonts installed. Also on this disk is Excel, Outlook, Power Point and Access, which I do not install.  I do a custom installation but I could not find any option to install any fonts.  On disk 2 from which I install Publisher, there is the option to install some fonts, which also show up in Word.  I can delete these fonts in the Windows font folder without any messages showing up when opening a document.  The method I described in the previous reply also works on my computer.
    I forgot to mention that if you use a registry cleaner tool such as CCleaner, then the altered hidden fonts will appear in the list from a registry scan.  I don't know what would happen if you let this program delete them.  To prevent this, uncheck the box next to fonts in the registry cleaning list before doing a scan.
    2013-01-19T02:24:29+00:00
    Thanks again.
    It seems to have worked for me, but it's a good idea to uncheck fonts in CCleaner to prevent any possible problem.
    Best,
    FP
