Removing foreign language fonts
2009-10-30T16:13:49+00:00
Does anyone know of a way to remove the many foreign language fonts from Windows 7? There wasn't an option to exclude them during setup. I've tried deleting them, but Windows tells me that they are system fonts which cannot be deleted. I've also tried "Hiding" them, but they still show up in the font list in Office and other programs. All I want and need are the basic English language fonts. Having to wade through dozens of useless (to me) fonts is a major annoyance. There should be a way to exclude them from my system if I don't need them.
2009-12-05T14:33:12+00:00
Hello mcbarker69,
The reason that I did not know the fonts in question is because no particular fonts were mentioned, and I had gone into fonts and removed a couple foreign fonts with no problem. However that being said, in order to remove the fonts that are being referred to follow these steps:
Take ownership of the file:
 - Click Start Orb > type fonts in the search box > click Fonts
 - Right-click the font > click Properties - Click Security tab > click Advanced - Click Owner > click Edit - Select your Username > click OK
Click OK on the Windows Security box
Change Permissions of the file:
 - Click Permissions > click Change Permissions
 - Select your Username > click Edit
 - Checkmark Allow for Full control
 - Click OK - Click OK
Click Yes on the Windows Security box
 - Click OK
You will need to remember the names of your font(s) that you want to delete.
Delete the file:
Will need to start Safe mode with command prompt
Restart your computer and tap F-8 continually, this will bring you to your Advanced Boot Options, select Safe mode with command prompt.
Once you have booted:
In command prompt navigate to fonts:
 - type cd c:\windows\fonts > press enter
 - type del "font name" > press enter *Do not use the quotes around the font name
This should bring you back to a clean prompt.
Once you are finished > Ctrl+Alt+Del > select restart from the arrow in the bottom right corner of your screen and start Windows normally.
Hope this helps
As the Windows Security box states; this could cause Windows to act differently. Make sure you know which fonts you are removing and that Windows does not need them before you remove any protected system fonts. This could cause many complications with your installation of Windows.
Chris.H
133 additional answers
    2011-02-04T23:37:25+00:00
    You obviously don't use any non-Microsoft software on a regular basis which allows adding text (Adobe suites or other graphics utilities, for example). Having to wade through the dozens of useless fontsEVERYtime you want to add text to something, is both time consuming and annoying. For those of us who really don't need, or want these intrusive fonts (probably around 95% of us in English speaking countries), these fonts represent yet another bad programming decision by Microsoft. It isn't a matter of hard disk drive space. Now if MS had included the ability to hide, or delete the unwanted fonts in non-Microsoft environments, this thread probably wouldn't exist.
    2011-02-06T01:10:01+00:00
    Totally agree. Never an issue until I open Photoshop one of the eight times a day.
    Has anyone installed SP1 yet and does it tackle this problem? I'm not holding my breath.....
    Well, That's My Two-penneth Worth
    2011-02-09T14:49:22+00:00
    Excellent and accurate comments!
    I hope your words don't fall on deaf ears.
    2011-03-26T13:21:43+00:00
    Well, here we are over a year down the road with Windows 7and with the latest SP1 installed, we find that nothing has changed as far as the ability to delete fonts in a simple manner. I have tried every suggestion in this thread only to find that it has caused more problems. Fortunately, the System Restore has helped get me back to a normal condition.  It is more than obvious that Microsoft's dream team feels that the customer is an idiot who should not question the infinite wisdom of it's choices. However, I have found a solution to this problem which, while costly in the short term has been found, at least for me, to more than pay off. I am now using an Apple iMac. I still use the PC and Windows 7 for tasks that do are simple. When I consider all of the infinite stupid and useless changes that have been made by MS in Windows 7, the Mac is a dream to use. It is hard to imagine a group of Microsoft engineers sitting around a table and choosing to substitute a simple operation developed in Windows XP in favor of a complex operation for Windows 7. I have spent literally months trying to solve many Windows 7 problems in all areas from the Mail, Video, Audio, Fonts, etc. To add to the misery, trying to talk with someone from India or other foreign country to solve the problem simply compounded the issue. I have done a clean and install no less than 7 times to correct problems they have caused after they "took control" of my computer and "fixed" the problem. For me, this time, frustration, dollars, and energy lost is not worth it. The cost of the Mac more than made up for this. It is no wonder that Apple is making such inroads, and doing it for the masses in a simple manner. It is a no-brainer. I am sure that those at Microsoft are scratching their heads trying to figure out what went wrong. They might try reading these forums and doing something about it in a timely manner. I will never consider another PC purchase or recommendation.
