Removing foreign language fonts
2009-10-30T16:13:49+00:00
Does anyone know of a way to remove the many foreign language fonts from Windows 7? There wasn't an option to exclude them during setup. I've tried deleting them, but Windows tells me that they are system fonts which cannot be deleted. I've also tried "Hiding" them, but they still show up in the font list in Office and other programs. All I want and need are the basic English language fonts. Having to wade through dozens of useless (to me) fonts is a major annoyance. There should be a way to exclude them from my system if I don't need them.
2009-12-05T14:33:12+00:00
Hello mcbarker69,
The reason that I did not know the fonts in question is because no particular fonts were mentioned, and I had gone into fonts and removed a couple foreign fonts with no problem. However that being said, in order to remove the fonts that are being referred to follow these steps:
Take ownership of the file:
 - Click Start Orb > type fonts in the search box > click Fonts
 - Right-click the font > click Properties - Click Security tab > click Advanced - Click Owner > click Edit - Select your Username > click OK
Click OK on the Windows Security box
Change Permissions of the file:
 - Click Permissions > click Change Permissions
 - Select your Username > click Edit
 - Checkmark Allow for Full control
 - Click OK - Click OK
Click Yes on the Windows Security box
 - Click OK
You will need to remember the names of your font(s) that you want to delete.
Delete the file:
Will need to start Safe mode with command prompt
Restart your computer and tap F-8 continually, this will bring you to your Advanced Boot Options, select Safe mode with command prompt.
Once you have booted:
In command prompt navigate to fonts:
 - type cd c:\windows\fonts > press enter
 - type del "font name" > press enter *Do not use the quotes around the font name
This should bring you back to a clean prompt.
Once you are finished > Ctrl+Alt+Del > select restart from the arrow in the bottom right corner of your screen and start Windows normally.
Hope this helps
As the Windows Security box states; this could cause Windows to act differently. Make sure you know which fonts you are removing and that Windows does not need them before you remove any protected system fonts. This could cause many complications with your installation of Windows.
Chris.H
133 additional answers
    2010-08-04T20:31:48+00:00
    Hi Gyan
    Thank you for taking the time to let us know that MS isn't ignoring this problem. I work with several graphics programs on a regular basis, each of which offers every system font in the Win7 list. At least, with Office, one can hide many of the foreign language fonts, but not so with non-MS programs. The ability to remove these fonts should be a major priority for Win7 SP1. Again, thank you for the information.
    2010-08-10T21:01:46+00:00
    For me what is really frustrating about this is not so much that there are scores of fonts I will never ever use, but the fact that the guaranteed list I will NEVER use always appears at the top! If there is going to be an @ symbol, why not put it before Arial and Times New Roman--or better yet, let me pick my 5-10 favorites? Why force Batang and GungSu and DontCare and ThisStinks (my translation of the Asian fonts) to the top? Who made that decision?
    I am painstakingly following the instructions above, but since I may have dozens of fonts that I want to delete, it is frustrating also to have to go into each one individually and jump through all the hoops of reassigning the permissions. Microsoft does not pay me for this, yet I have to take a significant amount of work time to do this.
    2010-08-13T18:37:12+00:00
    What an impressive ten-month thread!  Yet, still no easy fix either from Microsoft or from all these resourceful tech gurus.  Until now...  I stumbled on a simple solution.
    On a long-shot, I downloaded a program I found on C-NET's software site (http://download.cnet.com/windows/) that had good reviews and the uncatchy name of "High-Logic MainType" (from high-logic.com).
    This simple program effortlessly allowed me to uninstall the long list of unwanted files that are otherwise so difficult to remove and sent them to a backup directory.  (To be safe, in case I later need, say, Lao I did not delete any files.) Three quick clicks (right click, uninstall, yes) and done! Sweet. Uncluttered.
    Before Windows will let MainType load, it always prompts you to affirm that you want to allow the "program to make changes to the computer."  Presumably, that way it gets authority to uninstall those protected fonts (as well as regular fonts). The program has many other features for font management that I have found helpful today -- but just its power to delete the several dozen unwanted, menu-muddying fonts makes it more than worth its $49 price!
    Problem solved!
    2010-08-26T21:29:51+00:00
    Well, BillyXXX, as you say, "Problem solved!" But it's just one more instance of having to buy a third-party application just to make a Microsoft piece of s.... s.... software! work properly, or work at all. I recently upgraded to Win 7 Pro, quite reluctantly I might add. I was reassured that I could make my legacy apps (expensive apps!) work by using XP Mode - which is why I had to upgrade to Pro. What a headache that was. And talk about jumping through the hoops.
    I am one to plead with Microsoft to fix this $%&^$# font issue. I'm not technical. I'm neither a programmer, a developer, nor a system administrator. I'm a user. Wading through all of those fonts in a font selection screen in apps such as FrameMaker, CorelDraw, or PhotoShop, is a royal pain, time consuming, and confusing. It also precludes my installing many of the fonts that I've been using simply because adding them would make the list even longer and harder to work with. If there is a fix, I don't want to have to even think about going to the command line to do something about it. All of these proposed work-arounds are all well and good, but they aren't for the average user. Isn't the whole idea of a computer to make our lives and our work simpler, easier, and faster? In that respect, Microsoft is going in the wrong direction.
