Removing foreign language fonts
2009-10-30T16:13:49+00:00
Does anyone know of a way to remove the many foreign language fonts from Windows 7? There wasn't an option to exclude them during setup. I've tried deleting them, but Windows tells me that they are system fonts which cannot be deleted. I've also tried "Hiding" them, but they still show up in the font list in Office and other programs. All I want and need are the basic English language fonts. Having to wade through dozens of useless (to me) fonts is a major annoyance. There should be a way to exclude them from my system if I don't need them.
2009-12-05T14:33:12+00:00
Hello mcbarker69,
The reason that I did not know the fonts in question is because no particular fonts were mentioned, and I had gone into fonts and removed a couple foreign fonts with no problem. However that being said, in order to remove the fonts that are being referred to follow these steps:
Take ownership of the file:
 - Click Start Orb > type fonts in the search box > click Fonts
 - Right-click the font > click Properties - Click Security tab > click Advanced - Click Owner > click Edit - Select your Username > click OK
Click OK on the Windows Security box
Change Permissions of the file:
 - Click Permissions > click Change Permissions
 - Select your Username > click Edit
 - Checkmark Allow for Full control
 - Click OK - Click OK
Click Yes on the Windows Security box
 - Click OK
You will need to remember the names of your font(s) that you want to delete.
Delete the file:
Will need to start Safe mode with command prompt
Restart your computer and tap F-8 continually, this will bring you to your Advanced Boot Options, select Safe mode with command prompt.
Once you have booted:
In command prompt navigate to fonts:
 - type cd c:\windows\fonts > press enter
 - type del "font name" > press enter *Do not use the quotes around the font name
This should bring you back to a clean prompt.
Once you are finished > Ctrl+Alt+Del > select restart from the arrow in the bottom right corner of your screen and start Windows normally.
Hope this helps
As the Windows Security box states; this could cause Windows to act differently. Make sure you know which fonts you are removing and that Windows does not need them before you remove any protected system fonts. This could cause many complications with your installation of Windows.
Chris.H
133 additional answers
    2010-07-11T06:03:37+00:00
    Here is a great workaround solution to the problem that doesn't involve tedious ownership transferring:
    Go to the Fonts directory
    On the left panel select "Font Settings"
    Check "Allow Fonts to be installed using a shortcut (advanced)
    Copy all of the system fonts that you don't want into a different directory
    Select all of the moved fonts and right click
    Select "Install Font as Shortcut"
    Now go back to the Fonts directory
    Delete all of the unnecessary fonts which are now deletable because they are shortcuts!
    Voila!
    2010-07-12T09:34:44+00:00
    T.B.H the tedious bit is making a shortcut,making a folder, moving the fonts that you will never use. Apart from the fact we are talking SYSTEM fonts here.
    Well, That's My Two-penneth Worth
    2010-07-18T22:30:32+00:00
    I have to add my voice here, hoping Microsoft listens. I too am someone who has worked with MS products for a long time (since MS-DOS 2.0) and I have never seen such a bonehead UI choice. This megalist of fonts costs me seconds to minutes *every time* I make a font choice. It's an abomination. I'm not willing to resort to the font moves suggested here, not least because I expect the next Service Pack either to barf when it sees missing fonts, or else reinstall them. Instead, I've had to resort to making a separate list of actually useful fonts. This is ridiculous. I haven't had to do something like this since about 1990. Microsoft, listen to your users here. This is absurd. Give us control over our fonts. -= Skip =-
    2010-08-04T18:09:02+00:00
    Hi Skip,
    Thank you for sharing your thoughts, you can be sure that Microsoft listens and considers all users opinions. We are currently aware of the situation and how the current font enumeration mechanism could be a pain for some users. I can let you know that we are considering several options to make the process of finding a suitable font more focused, and to make the font removing process simpler.
    Best Regards
