Hello Christi,
This is a known issue with the HP Solution Center and upgrading from Windows Vista to Windows 7. Basically the HP Solution Center doesn’t upgrade properly to Windows 7 because of some required libraries don’t get migrated during the upgrade. To resolve the issue, click Start, All Programs and click Windows Update, and then check for and install the update for KB 975891.
For more information on the issue, click the link below to view the KB article.
KB975891 HP Multifunction Printers and HP Full Feature Software or HP Basic Driver solutions do not work as expected after a computer upgrades from Windows Vista to Windows 7
Note: You can also download and install the appropriate HP device software for Windows 7 from http://www.HP.com
Bobby
1
person needs an answer
