HP Multi-function printers may not work as expected after upgrading from Windows Vista to Windows 7
2009-10-22T17:30:56+00:00
I just upgraded to Windows 7 from Windows Vista and my HP multi-function printer doesn’t work. I can still print if I print from an application but when I try to use the buttons on the printer nothing happens. I also can’t check things like ink levels and I can’t scan. Is this a known issue? What can I do to fix this?
Christi
2009-10-22T17:31:47+00:00
Hello Christi,
This is a known issue with the HP Solution Center and upgrading from Windows Vista to Windows 7. Basically the HP Solution Center doesn’t upgrade properly to Windows 7 because of some required libraries don’t get migrated during the upgrade. To resolve the issue, click Start, All Programs and click Windows Update, and then check for and install the update for KB 975891.
For more information on the issue, click the link below to view the KB article.
KB975891 HP Multifunction Printers and HP Full Feature Software or HP Basic Driver solutions do not work as expected after a computer upgrades from Windows Vista to Windows 7
Note: You can also download and install the appropriate HP device software for Windows 7 from http://www.HP.com
Bobby
70 additional answers
    2009-10-23T15:10:55+00:00
    This is also a problem with xerox multi function printers, Scanner works unable to get print spooler started. WILL NOT RECCOMEND UPGRADE for bussiness users till issuse is fixed. and since I'm a small bussiness microsoft will of course ignore me like it always does!!!!!!!!!!!!!!!!!!
    2009-10-25T20:32:36+00:00
    I also cannot get the scanner on my HP CM1017 MFP to work.  It's as if the scanner doesn't exist.
    2009-10-25T23:53:27+00:00
    I am sorry dareddog, but it is bunch of bs, and you know it.
    How is it Microsoft fault when HP refused to support their own products? I bought (for example) LJ3015 not so long ago, and guess what ... NO support for VISTA 64 nor Windows 64 bit.  HP simply REFUSED to port / patch THEIR application to even install.  BROTHER and others have done it for their users very promply (check their websites, google it... oops ... bing it!). This made me rethink my position on HP as a company. From now on I will try to avoid them like a plague.... I bought their original  Windows Home SERVER EX475 ... Same ____ (excuse my anger, all the therapy down the drain...).  2 years, and 3 newer  models later, they left me and others hanging without real support (no software upgrade/maintenance).  Real business "geniuses"! I guess they must have graduated from the oh-so-famous Intuit "Customer ill-service University".... another Silicon Valley software disaster .... but I digress.
    BTW, I WAS able to get the full functionality for my LJ3015 using both professional FAX and SCAN application and by using Virtual environment to install the original HP software. Now I AM happy ....(not with HP that is).
    2009-10-25T23:55:54+00:00
    Rassi,
    Did you try to run it under XP Mode (Professional, Ultimate versions only)?. I got my LJ3015 all-in-one work. Also these versions of Windows 7 have their own FAx and Scan application, which may work with your printer.
