My battery is set up to charge to 80%. How to I change it to charge a 100%?
2010-01-31T15:47:12+00:00
I have a laptop samsung Q320
Thanks!
2010-03-13T05:58:33+00:00
Click "Start" > All programs > Samsung > Battery Life Extender > Battery Life Extender .  Click "yes" if prompted. When the program launches you should have the option to go back and forth between 100 and 80% on your battery.
Hope this is what you were looking for.
2010-02-01T04:55:34+00:00
Hi MEY85,
Since you need support for the Samsung Laptop battery to setup a charge of 100%, you may need to get in touch with Samsung for further assistance.
You may refer the following link to contact Samsung:
http://www.samsung.com/us/info/contactus.html#
Praseetha K
45 additional answers
    2012-08-09T13:41:18+00:00
    thanks for ur  post
    2012-09-11T13:54:46+00:00
    I have a SamsungNP300E5A.  I have it set to where the battery will charge to 80%, but it only reaches 79%.  Is this normal?
    2012-10-25T05:51:23+00:00
    You have to disable  the "battery life cycle" setting in BIOS.. i.e.
    press F2 on startup, get to the option "battery life cycle" and change it to disable from its default enable state.
    save and exit settings
    And  you can be loaded 100%
    Regards,
    Sanjay
    PS - Replied for new users, i am sure MEY85 is happily charging to 100%
