My battery is set up to charge to 80%. How to I change it to charge a 100%?
2010-01-31T15:47:12+00:00
I have a laptop samsung Q320
Thanks!
2010-03-13T05:58:33+00:00
Click "Start" > All programs > Samsung > Battery Life Extender > Battery Life Extender .  Click "yes" if prompted. When the program launches you should have the option to go back and forth between 100 and 80% on your battery.
Hope this is what you were looking for.
2010-02-01T04:55:34+00:00
Hi MEY85,
Since you need support for the Samsung Laptop battery to setup a charge of 100%, you may need to get in touch with Samsung for further assistance.
You may refer the following link to contact Samsung:
http://www.samsung.com/us/info/contactus.html#
Praseetha K
45 additional answers
    2014-01-11T09:17:20+00:00
    This is the best answer it just solved my woes!...
    2014-10-24T15:21:23+00:00
    Many thanks! Been struggling to sort this out for ages.
    2016-01-31T22:18:43+00:00
    Great for any release prior to Window 10.  See response from Samsung below:
    **Vamshi B:**I have checked the information. I see that the Battery life extender is not compatible with Windows 10.
    **Vamshi B:**If you want to reset the settings, you need to roll back to Windows 7, then change the settings and update the Laptop.
    Doesn't seem like a very practical solution to me.
