need to reinstall exetender player
2009-04-02T14:02:55+00:00
hi i deleted chronical dreams from free ride games and the exetender player by mistake cause it was downloaded the same date as the game i didnt think i needed the player anymore thought it was part of the game. everytime i turn on my gateway laptop when it lods i get this box stateing... Invalid or missing resource files in the installation directory. Please reinstall Extender Player. i try reinstalling the game but it still gives me the box Exeteder fatal error what can i do i cant even delete the game again cuase its missing specified file cant be found... can any one help please i will appreciate it thank you in advance have a good day
Windows for home | Other | Gaming
2009-04-02T21:28:23+00:00
Hi evieboop,
Thank you for posting.
You can refer to your game provider and how you properly uninstall their program. You can also try using “System Restore” and see if you can go back to a point before you installed your game.
I would suggest that you back up your system first before making any other changes to your system. Just for future reference
THIRD PARTY SOFTWARE DISCLAIMER
Using Third Party Software, including hardware drivers can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the use of Third Party Software can be solved. Using Third Party Software is at your own risk.
Good luck,
JohnD
57 additional answers
    2009-04-04T07:15:53+00:00
    hi johnd i did try system restore but i had deleted the game n the player that same morning because it kept crashing my mozilla firefox so i deleted them to reinstall the game back, it installed the game back but it kept crashing my firefox i try installing 2 times the second time i try deleting the game it give me a fatal error that some file is missing in the instalation directory n to reinstal the extender player. now i cant play that game and others from the freeridegames.com what i rewant is to uninstll it for good but i need the extender player file thats missing in order for it to uninstall.even when i reinstalled the game it still gives me that fatal error. oh when i try the recovery later at night it only gave me only 1 restore pt earlier from that morning but the file wasnt in that restore pt it kept giving me the same error
    ****** do you think that extender player installed the first time with the game or did it come already with the files software in my gateway windows vista 32bit?????
    if theres any other way i can delete the game from my remove programs please let me know so i can stop getting this error when my lappy (laptop) loads thank you so much god bless
