How to change monitor 1 for monitor 2
2010-05-05T20:48:00+00:00
I have a Gateway with HDMI and Vga outputs. I connect the VGA to a regular computer monitor, and the HDMI to a new 37 HDTV, but by default the HDMI output is identified as Monitor 1 and the vga to monitor 2, I new to change the identity of the monitors so 1 to be 2 and 2 to be 1, please advice
2010-05-05T22:36:14+00:00
Right Click Desktop - Graphics Properties
Right Click Desktop - Graphics Options
Right Click Desktop - Personalize - Display Settings
These should help you set them up.
How to Setup Dual Monitors in Windows 7
http://www.online-tech-tips.com/windows-7/how-to-setup-dual-monitors-in-windows-7/
Two monitors are better than one
http://www.microsoft.com/athome/organization/twomonitors.aspx
Work and play better with multiple monitors
http://windows.microsoft.com/en-us/windows7/work-and-play-better-with-multiple-monitors
Move windows between multiple monitors
http://windows.microsoft.com/en-US/windows7/Move-windows-between-multiple-monitors
Multiple monitors : frequently asked questions.
http://windows.microsoft.com/en-AU/windows-vista/Multiple-monitors-frequently-asked-questions
Hope this helps.
Rob Brown - Microsoft MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
51 additional answers
    2016-02-02T21:14:19+00:00
    The only thing you should have to do to quickly fix any of these issues with windows identifying monitors with a certain id or number is simply swap the cables on the back of your pc, laptop, or docking station (whichever you are using). That is the easiest way to change how windows sees which monitor has which monitor id or number.
    Just go on the back of your docking station, usb hub, or desktop and switch the cables. Let's say you have monitor "1" (which is physically on the right side of the desk) plugged into hdmi port 2 on the dock or video card and you have monitor "2" (which is physically on the left side of the desk) plugged into hdmi port 1 on the video card. Just switch monitor "1" so it's plugged into hdmi port 1 instead of hdmi 2 and then plug monitor "2" into hdmi port 2 instead of hdmi 1. Or maybe it's DVI or display port or any combination of these. It really doesn't matter. The point is you just need to switch around which ports each monitor is physically attached to on the video card or dock in order for windows to label and identify them differently.
    2016-02-03T01:09:52+00:00
    We've all tried this already, it doesnt work.  Which is why we're all frustrated.
    2016-02-03T02:02:48+00:00
    Hmm. Thats really odd. I just tried it myself. Worked flawlessly. This must be something specific to docking stations. The OP mentioned a dock correct? And I saw others mentioning docks. I know it works on a regular desktop. I've done it on many different ones and various video cards. It's possible that it's something to do with how windows recognizes ports from the video card that is on board on the laptop versus how it sees the ports which are part of the docking station. Ultimately the graphics are derived off the on board video card from the laptop but I imagine there is something inconsistent with how the ports are recognized on the dock versus the laptop.
    That is really strange. I've done this so many times with various versions of Windows and on multiple pieces of hardware over the years. But I cant remember if any specifically had a dock station involved.
    2016-02-03T02:05:11+00:00
    Really? That is Microsoft's answer??
    I cannot swap cables..You really thought we did not thought about that before struggling with all the possible solutions?...
    Simply my graphic card has 1hdmi, 2DP and 1 DVI.. TV can only use hdmi.. And 1 monitor has only DP and the other one only DVI. So there is only way for me and many others to connect such a setup of monitors with TV..
    I really hopped this will get fixed in win10.. Frustration even higher when I upgraded to 10 just because of that and not fixed even there.. Exactly same situation.
