How to change monitor 1 for monitor 2
2010-05-05T20:48:00+00:00
I have a Gateway with HDMI and Vga outputs. I connect the VGA to a regular computer monitor, and the HDMI to a new 37 HDTV, but by default the HDMI output is identified as Monitor 1 and the vga to monitor 2, I new to change the identity of the monitors so 1 to be 2 and 2 to be 1, please advice
2010-05-05T22:36:14+00:00
Right Click Desktop - Graphics Properties
Right Click Desktop - Graphics Options
Right Click Desktop - Personalize - Display Settings
These should help you set them up.
How to Setup Dual Monitors in Windows 7
http://www.online-tech-tips.com/windows-7/how-to-setup-dual-monitors-in-windows-7/
Two monitors are better than one
http://www.microsoft.com/athome/organization/twomonitors.aspx
Work and play better with multiple monitors
http://windows.microsoft.com/en-us/windows7/work-and-play-better-with-multiple-monitors
Move windows between multiple monitors
http://windows.microsoft.com/en-US/windows7/Move-windows-between-multiple-monitors
Multiple monitors : frequently asked questions.
http://windows.microsoft.com/en-AU/windows-vista/Multiple-monitors-frequently-asked-questions
Hope this helps.
Rob Brown - Microsoft MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
51 additional answers
  1. Deleted
    2015-11-02T16:24:31+00:00
    I agree it does matter.   For some it is an issues with programs not responding properly and for others it mainly a numbering issue; for me it is both.  Our IT groups has to remote into computer to help install programs of fix issues with computers.  But when we remote into a computer that is using 3 monitors, 2 24" HP monitors and 1 laptop monitor we seem to run into the issue of IT seeing one thing and the person computer being remoted into seeing another.  For instance, if a window pops up while installing and I need to click on OK it appears that I am clicking on the button on my monitor but the other person sees me clicking on blank space or an icon on their desktop...
    I noticed this morning that my monitor showed two different setups, one through NVidia nView Desktop Manager and another through Screen Resolution (Right click on desktop and select screen resolution).  The NVidia showed: 2, 3, 1.  (2 far left, 3 middle and main display, and 1 laptop) when I clicked on identify.  When I looked at the screen resolution it showed the same thing in the area that lets you adjust the displays loction.  However when I clicked on identify I got something completely different: 3, 2, 1 (3 far left, 2 middle and main display, and 1 laptop).  I believe this is where the issues live when it comes programs not acting as intended...
    Microsoft or NVidia needs to figure this out because it is a big issue.
    The images below show the issue.  All I did was select Identify from both options and this is what I am given.
    NVidia nView Desktop manager
    Desktop Manager
    2015-11-19T00:42:09+00:00
    I am facing the same issue with CCC and Win10Pro. And yes, it does matter very much which monitor has which number. In my case, it affects how my NLE sees the preview monitor causing it to be displayed on the wrong monitor or not at all.
    No solution? No registry hack?
    2015-12-21T20:57:19+00:00
    Same here!!! Fix this problem finally... users are complaining since 2009!!!!
    BTW: This REG_FIX was in my opinion closest to the final solution... but it didnt work.. believe me, I have tried all possible solutions google could tell..
    I have 2 monitors (DP->ID1, DVI->ID2) and no matter what I do (if I turn off monitor it doesnt help.. need to physically disconnect other one to have DVI as "main" one) always monitor via DVI, which I want to be my main, gets recognized as projector.. This creates 1 big issue for me, where AMD card does not detect anything on "main" monitor, it will go idle -> limiting performance because: It consider only "main" monitor in windows as primary one, used for gaming, HD videos and so..  and what is happening on "projector" monitor it doesnt care thus ignoring what is going on there..  so it will go into idle mode..
    please finally have a look.. thanks
