How to change monitor 1 for monitor 2
2010-05-05T20:48:00+00:00
I have a Gateway with HDMI and Vga outputs. I connect the VGA to a regular computer monitor, and the HDMI to a new 37 HDTV, but by default the HDMI output is identified as Monitor 1 and the vga to monitor 2, I new to change the identity of the monitors so 1 to be 2 and 2 to be 1, please advice
2010-05-05T22:36:14+00:00
Right Click Desktop - Graphics Properties
Right Click Desktop - Graphics Options
Right Click Desktop - Personalize - Display Settings
These should help you set them up.
How to Setup Dual Monitors in Windows 7
http://www.online-tech-tips.com/windows-7/how-to-setup-dual-monitors-in-windows-7/
Two monitors are better than one
http://www.microsoft.com/athome/organization/twomonitors.aspx
Work and play better with multiple monitors
http://windows.microsoft.com/en-us/windows7/work-and-play-better-with-multiple-monitors
Move windows between multiple monitors
http://windows.microsoft.com/en-US/windows7/Move-windows-between-multiple-monitors
Multiple monitors : frequently asked questions.
http://windows.microsoft.com/en-AU/windows-vista/Multiple-monitors-frequently-asked-questions
Hope this helps.
Rob Brown - Microsoft MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
51 additional answers
    2014-11-11T17:53:21+00:00
    thanks, made life lot easier...... :)
    2014-11-11T19:39:45+00:00
    I found a better and easier solution to switch to your monitor identity basically switching 1 and 2.
    1. Turn off computer fully.
    2. Disconnect all DVI or monitor display. (In my case i have Benq (DVI) and Samsung (HDMI).
    3. Turn on computer and wait until its in the Log in screen. (You won't actually see it since all monitor is disconnected. Just guess or wait till you hear the log in sound).
    4. Connect the monitor that you want to be Display 1st. (Extra: Log in and open up display settings where you see display 1 and 2 for visualization purposes.)
    5. Then connect the monitor that you want to be Display 2nd.
    6. And so on. Voila!! hope this helps.
    Thanks! Unfortunately did not help a bit... It worked for a couple of people though based on the comments. Perhaps this has something to do with the fact I'm plugging monitors to a docking station not the laptop. Or could be related to the DisplayPort - the monitor that keeps taking over the #1 even when following your steps above and connecting it second - this monitor is connected to the UltraBase dock DisplayPort while the other monitor is on DVI... Oh, well, I guess I just have to keep on swapping open apps between the screens when I move between my docking stations :)
    2014-11-18T16:08:18+00:00
    That only works for icon displayed in the settings. Doesn't actually change moving left to right from screen to screen.
    2015-04-02T11:41:55+00:00
    I'm missing why the labels that Windows puts on two screens matters.
    I'm thinking that they could be called Annabel and Jeffrey rather than 1 and 2. I can't see that it would matter. We can set one screen as the main display, and we can drag each screen in the graphic so that the screens sit with respect to each other in the same way they sit in the physical world - the left one on the left, and the right one on the right.
    Mutatis mutandis for more than two screens.
    Things behave as you would expect, do they not?
