How to change monitor 1 for monitor 2
2010-05-05T20:48:00+00:00
I have a Gateway with HDMI and Vga outputs. I connect the VGA to a regular computer monitor, and the HDMI to a new 37 HDTV, but by default the HDMI output is identified as Monitor 1 and the vga to monitor 2, I new to change the identity of the monitors so 1 to be 2 and 2 to be 1, please advice
2010-05-05T22:36:14+00:00
Right Click Desktop - Graphics Properties
Right Click Desktop - Graphics Options
Right Click Desktop - Personalize - Display Settings
These should help you set them up.
How to Setup Dual Monitors in Windows 7
http://www.online-tech-tips.com/windows-7/how-to-setup-dual-monitors-in-windows-7/
Two monitors are better than one
http://www.microsoft.com/athome/organization/twomonitors.aspx
Work and play better with multiple monitors
http://windows.microsoft.com/en-us/windows7/work-and-play-better-with-multiple-monitors
Move windows between multiple monitors
http://windows.microsoft.com/en-US/windows7/Move-windows-between-multiple-monitors
Multiple monitors : frequently asked questions.
http://windows.microsoft.com/en-AU/windows-vista/Multiple-monitors-frequently-asked-questions
Hope this helps.
Rob Brown - Microsoft MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
51 additional answers
    2017-05-05T06:57:51+00:00
    Hey davecook03,
    I don't think there is a way to change the labels for your monitors but there is a solution to your problem. While you're looking at the display settings, under the "Change the appearance of yours displays there's a small diagram showing your two monitors. Right now it probably shows monitor 1 on the left and monitor 2 on the right.
    All you need to do is click and drag monitor 2 in the diagram to the left side of monitor 1. This should solve your problem and make dragging windows from one monitor to the other much more intuitive.
    thx dude u just solved my problem at work... and u know what.. i am freakin using computer more than 20 years but i have never needed and imagined that that display can be dragged and dropped :D Hah... thx again..
    2017-05-15T13:13:01+00:00
    https://www.intel.com/content/www/us/en/support/graphics-drivers/000023783.html
    Using this interface I was able to assign different numbers to the displays.
    2017-09-22T00:38:21+00:00
    Never thought dragging was an option! Thanks!
