How to change monitor 1 for monitor 2
2010-05-05T20:48:00+00:00
I have a Gateway with HDMI and Vga outputs. I connect the VGA to a regular computer monitor, and the HDMI to a new 37 HDTV, but by default the HDMI output is identified as Monitor 1 and the vga to monitor 2, I new to change the identity of the monitors so 1 to be 2 and 2 to be 1, please advice
2010-05-05T22:36:14+00:00
Right Click Desktop - Graphics Properties
Right Click Desktop - Graphics Options
Right Click Desktop - Personalize - Display Settings
These should help you set them up.
How to Setup Dual Monitors in Windows 7
http://www.online-tech-tips.com/windows-7/how-to-setup-dual-monitors-in-windows-7/
Two monitors are better than one
http://www.microsoft.com/athome/organization/twomonitors.aspx
Work and play better with multiple monitors
http://windows.microsoft.com/en-us/windows7/work-and-play-better-with-multiple-monitors
Move windows between multiple monitors
http://windows.microsoft.com/en-US/windows7/Move-windows-between-multiple-monitors
Multiple monitors : frequently asked questions.
http://windows.microsoft.com/en-AU/windows-vista/Multiple-monitors-frequently-asked-questions
Hope this helps.
Rob Brown - Microsoft MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
51 additional answers
    2016-10-17T08:38:11+00:00
    I found an easy way to switch 1 and 2 monitors between each other.  Get to the display option page where both of the monitors show as 1 and 2.  Same page you would be entering extend and etc.  Just click on one of the monitors and drag it over.  That is it.  No bios , no hassles.
    2016-10-27T10:59:53+00:00
    I have a sony vaio duo with a bad screen.  I went into pc settings in win 8.1 and told the screen to only show the 2nd screen which is a 27 inch vga plug in screen.  It asked me if I wanted to make it primary and I said yes.  Now the bad sony toubh screen is completely out of the picture.  I tested the 27 inch screen on a restore of image and it came up fine - whew.  So try declaring 2nd screen only and see if the pc asks you if you want to make it primary....Gene
    2017-01-07T21:59:29+00:00
    Glad you pointed that out.  I have 1 hdmi & 1 dvi port - 1 television and 1 computer monitor. I suppose it's possible to use 2 hdmi cables with an hdmi to dvi adapter on one end if switching ports works, but the consensus seems to be that it doesn't.
    2017-01-07T23:19:26+00:00
    The above comment I had posted did not work at the lowest level of bootup.  However when I removed the bad screen entirely from the pc and then plugged in an outboard hdmi monitor it did select that monitor at the lowest levels of bootup thus giving me a way to use my old pc with a burned out screen, at least use it as a desktop pc, and it is working well in that mode.  I have some pictures of the setup: http://egpreston.com/sonyvaio.pdf   good luck!
