How to change monitor 1 for monitor 2
2010-05-05T20:48:00+00:00
I have a Gateway with HDMI and Vga outputs. I connect the VGA to a regular computer monitor, and the HDMI to a new 37 HDTV, but by default the HDMI output is identified as Monitor 1 and the vga to monitor 2, I new to change the identity of the monitors so 1 to be 2 and 2 to be 1, please advice
2010-05-05T22:36:14+00:00
Right Click Desktop - Graphics Properties
Right Click Desktop - Graphics Options
Right Click Desktop - Personalize - Display Settings
These should help you set them up.
How to Setup Dual Monitors in Windows 7
http://www.online-tech-tips.com/windows-7/how-to-setup-dual-monitors-in-windows-7/
Two monitors are better than one
http://www.microsoft.com/athome/organization/twomonitors.aspx
Work and play better with multiple monitors
http://windows.microsoft.com/en-us/windows7/work-and-play-better-with-multiple-monitors
Move windows between multiple monitors
http://windows.microsoft.com/en-US/windows7/Move-windows-between-multiple-monitors
Multiple monitors : frequently asked questions.
http://windows.microsoft.com/en-AU/windows-vista/Multiple-monitors-frequently-asked-questions
Hope this helps.
Rob Brown - Microsoft MVP - Windows Desktop Experience : Bicycle - Mark Twain said it right.
51 additional answers
    2010-05-06T08:36:54+00:00
    You can better use a Winkey + P , which will launch you the projector options. In that choose Projector only , your new 37 HDTV will work as a display for your PC. Ping me if it has any conflicts.
    2011-07-18T06:10:39+00:00
    This doesn't solve the problem and neither does the reply labeled "answer". This makes it so the displays are no longer expanded. What I need is for the secondary monitor connected to my laptop to be labeled as monitor 1, and the one that's built in to my laptop to be labeled as monitor 2 (opposite what they are by default). It's not a simple concept that is displayed in the control panel easily but surely someone understands the problem. And, no, I don't want to change which monitor is the "main display" monitor, I need the number labels to be changed. This may be something that requires going into some obscure system file.
    2011-07-18T06:36:00+00:00
    Hi Wumbo,
    Please start your own thread and include the System Maker (Motherboard Maker for
    custom systems) and the Video card/device maker. Help us to help you.
    On many you can Right Click the Desktop - Graphics Properties - and assign either
    device as Monitor 1 (Primary device) or Monitor 2 (Secondary device).
    Check with the System Maker and the video card/device maker's support and forums.
    Hope this helps.
    Rob Brown - Microsoft MVP <- profile - Windows Expert - Consumer : Bicycle - Mark Twain said it right.
    2012-06-20T09:36:13+00:00
    I agree these guys dont know what there talking about just  cookie cutting useless answers.
    HERE IS THE PROBLEM :
    * Installed windows 7 with bolth HDMI monitors pluged into the system.
    * Windows chose the wrong one to be monitor 1
    * now when I open programs they auto open on to monitor 1 witch I cant see because thats my tv and Its looking at the cable box not the pc because I only use it with the pc when Im watching movies on the pc.
    HERE IS THE QUESTION:
    *HOW DO YOU CHANGE MONITOR 1 TO MONITOR 2 AND STAY THAT WAY THROUGH RESTARTING.
    note: in xp it was run type regedit, then go to HKEY_LOCAL_MACHINE/CURRENTCONTROLSET/ENUM/DISPLAY and delete the entry's but in windows 7 it tells you cannot delete ......:Error while deleting key.  no error code
