Applications stealing focus - reg key no longer fixes
2010-04-08T18:42:59+00:00
I want to prevent any applications from stealing focus in windows 7 (and Vista).  Tweakui used to modify the below Registry key to 0.  Then there was a key that affected the number of flashes a "want to steal focus" window would make in the taskbar.
ForegroundLockTimeout
HKEY_CURRENT_USER\Control Panel\Desktop
This reg key is apparently no longer working.  Focus stealing is a major problem, from canceling/oking window that pop-up, to getting virus's from IE windows.  Applications are still written to do this, including MS Office 2007.  If you are typing an email something can pop up and get the next key stroke.  I need to fix this.  Any ideas, or has Windows completely removed a needed feature.
tags: steal focus apps active regedit
2011-10-23T11:13:03+00:00
I solved the problem in this way:
I noticed that just before the focus was "stolen", the PC got "busy" for a second (beside the mouse appeared the small circle indicating the processor is working hard on sth).
So I started the Task Manager and gave a close look at the processes. I noticed that one process took over a relevat percentage of CPU usage exactly an instant before the focus was stolen from the task manager window.
Since it was a process that I don't need to be active all the time (sth about Vodafone Mobile connection, which I rarely use) I just stopped the process and then didn't allow the process to be started every time I turn on the PC. I did this last step using Piriform's free software  "CCleaner", but I'm sure you can find different tools for this...
This was enough to fix it ...
Hope this helped!
Bye!
166 additional answers
    2012-04-17T10:32:41+00:00
    Shawn,
    I've found a solution - using ARCH Linux with the KDE Desktop. The KDE Desktop which has multiple (global) configuration options for the level of focus stealing prevention application windows are subject to.
    Your answers are not helpful... Windows 7 is an empty shell till it has some 3rd party applications installed. If 3rd party applications are "misbehaving" then surely Windows 7 needs a "feature", like the one present in earlier Windows XP,  that can be turned on in order to 'disable' focus stealing.
    Like I said before (in this thread) try migrating a large iTunes library in your tests. Oh joy - my PC is unusable for 1-2 hours...
    If you don't work for MS perhaps you know someone who actually does?? Perhaps they could actually come on the thread, read all the hundreds of complaints and do something useful about this problem.
    Service pack 1 has hit and there is still no sign of a __working__ solution.
    Disappointed
    Mr Wya
    2012-04-24T10:14:23+00:00
    This just happened to me. I was typing in the search box in Firefox and the Proxy server dialog popped up unawares (corporate network)
    I ended up typing my search request into the username box without realising it
    No Operating System should allow this to happen, especially when the current focus is in a text box!!
    2012-05-04T02:23:16+00:00
    Hi Shawn
    I'm also mad with this issue.
    You told us that you need a way to reproduce it.
    Have you tried this one:
    Start -> execute -> cmd.exe -> OK
    type:
    ping -n 60 127.0.0.1 && notepad
    Now, in exactely 60 seconds notepad will steal the focus, you cannot prevent this behaviour.
    Please let me know if this is ok.
