Applications stealing focus - reg key no longer fixes
2010-04-08T18:42:59+00:00
I want to prevent any applications from stealing focus in windows 7 (and Vista).  Tweakui used to modify the below Registry key to 0.  Then there was a key that affected the number of flashes a "want to steal focus" window would make in the taskbar.
ForegroundLockTimeout
HKEY_CURRENT_USER\Control Panel\Desktop
This reg key is apparently no longer working.  Focus stealing is a major problem, from canceling/oking window that pop-up, to getting virus's from IE windows.  Applications are still written to do this, including MS Office 2007.  If you are typing an email something can pop up and get the next key stroke.  I need to fix this.  Any ideas, or has Windows completely removed a needed feature.
tags: steal focus apps active regedit
2011-10-23T11:13:03+00:00
I solved the problem in this way:
I noticed that just before the focus was "stolen", the PC got "busy" for a second (beside the mouse appeared the small circle indicating the processor is working hard on sth).
So I started the Task Manager and gave a close look at the processes. I noticed that one process took over a relevat percentage of CPU usage exactly an instant before the focus was stolen from the task manager window.
Since it was a process that I don't need to be active all the time (sth about Vodafone Mobile connection, which I rarely use) I just stopped the process and then didn't allow the process to be started every time I turn on the PC. I did this last step using Piriform's free software  "CCleaner", but I'm sure you can find different tools for this...
This was enough to fix it ...
Hope this helped!
Bye!
166 additional answers
    2012-03-30T08:36:53+00:00
    It's a pain.
    Maybe my brand new laptop is especially serverly hit by "focus stealling", it happens all the time, when I don't use full screen. E-mails is deleted, characters written in wrong documents ect.
    2012-04-13T09:41:35+00:00
    Hi Shawn,
    Thanks for your patience. I have the problem for several years on a computer with many programs. I will fill in your form after upgrading my system in as many ways I can.
    One intereresting point: Photoshop is constantly stealing my focus but Indesign and Illustrator as well as Office programs are not. I also think it is a driver/graphic card issue.
    2012-04-13T09:44:23+00:00
    This issue can be easily reproduced by using Nlite to slipstream a bunch of hotfixes into an XP CD, when nlite begins the slipstreaming process and rebuilding cabinet files it will steal focus continuously from other apps (over 100 times it stole focus), I just slipped over 100 hotfixes using nlite the other day, I had to walk away from the PC while it did its job, it made using the PC impossible.
    I know it is the fault of nlite and was not written/optimized for W7, but my god Windows should have the ability to stop this behavior somehow.
    It is actually not nLite's fault but of hotfix update.exe program. The author tried to block the focus stealing but no luck.
