Applications stealing focus - reg key no longer fixes
2010-04-08T18:42:59+00:00
I want to prevent any applications from stealing focus in windows 7 (and Vista).  Tweakui used to modify the below Registry key to 0.  Then there was a key that affected the number of flashes a "want to steal focus" window would make in the taskbar.
ForegroundLockTimeout
HKEY_CURRENT_USER\Control Panel\Desktop
This reg key is apparently no longer working.  Focus stealing is a major problem, from canceling/oking window that pop-up, to getting virus's from IE windows.  Applications are still written to do this, including MS Office 2007.  If you are typing an email something can pop up and get the next key stroke.  I need to fix this.  Any ideas, or has Windows completely removed a needed feature.
tags: steal focus apps active regedit
2011-10-23T11:13:03+00:00
I solved the problem in this way:
I noticed that just before the focus was "stolen", the PC got "busy" for a second (beside the mouse appeared the small circle indicating the processor is working hard on sth).
So I started the Task Manager and gave a close look at the processes. I noticed that one process took over a relevat percentage of CPU usage exactly an instant before the focus was stolen from the task manager window.
Since it was a process that I don't need to be active all the time (sth about Vodafone Mobile connection, which I rarely use) I just stopped the process and then didn't allow the process to be started every time I turn on the PC. I did this last step using Piriform's free software  "CCleaner", but I'm sure you can find different tools for this...
This was enough to fix it ...
Hope this helped!
Bye!
166 additional answers
    2011-12-30T03:32:16+00:00
    Can you tell me how you reproduce it on a fresh install?  I can't seem to trigger it on any of my PC's at will.  I've tried using the command prompt to start items after a delay and such (and other methods, scheduled tasks, whatever) and they always show behind my current window (and flash on the taskbar).  If I can reproduce it with your method, since you're on a fresh install, I can work deeper to find the root cause.
    1. Create a new email message in Outlook (2010).
    2. Click in Taskbar, Start Menu, etc. to start Photoshop.
    3. Click back in the new email and start typing. Photoshop steals focus every time.
    This is a Windows installation that is less than a month old.
    David Salahi
    2012-01-03T22:32:37+00:00
    Until the developers themselves get affected by an unintended shutdown/reboot in the middle of two dozen open applications and documents in the middle of a work day will this be swiftly remedied.
    Please fix this oversight and bring back the ForegroundLockTimeout variable or a systems preference enabled in the UI to accomplish a lock on whatever window the USER selects as THEIR focus, period.
    As a 15-year veteran Windows user, it's utter rubbish this problem still exists.
    2012-01-06T14:32:51+00:00
    I have been struggling with this issue since windows 7 came out. Today my machine became a single-tasking machine for an hour as ran some batch files and CMD.exe keep taking focus at the onset of each batch file. My machine was unusable as command windows popped up ever second.
    Ridiculous!
