Applications stealing focus - reg key no longer fixes
2010-04-08T18:42:59+00:00
I want to prevent any applications from stealing focus in windows 7 (and Vista).  Tweakui used to modify the below Registry key to 0.  Then there was a key that affected the number of flashes a "want to steal focus" window would make in the taskbar.
ForegroundLockTimeout
HKEY_CURRENT_USER\Control Panel\Desktop
This reg key is apparently no longer working.  Focus stealing is a major problem, from canceling/oking window that pop-up, to getting virus's from IE windows.  Applications are still written to do this, including MS Office 2007.  If you are typing an email something can pop up and get the next key stroke.  I need to fix this.  Any ideas, or has Windows completely removed a needed feature.
tags: steal focus apps active regedit
2011-10-23T11:13:03+00:00
I solved the problem in this way:
I noticed that just before the focus was "stolen", the PC got "busy" for a second (beside the mouse appeared the small circle indicating the processor is working hard on sth).
So I started the Task Manager and gave a close look at the processes. I noticed that one process took over a relevat percentage of CPU usage exactly an instant before the focus was stolen from the task manager window.
Since it was a process that I don't need to be active all the time (sth about Vodafone Mobile connection, which I rarely use) I just stopped the process and then didn't allow the process to be started every time I turn on the PC. I did this last step using Piriform's free software  "CCleaner", but I'm sure you can find different tools for this...
This was enough to fix it ...
Hope this helped!
Bye!
166 additional answers
    2010-11-12T04:12:49+00:00
    $66 Data Recovery Software now FREEtoday in PCWatch.com!
    This is PCWatch’s Jessica Alba Week ! PCWatch prepares a big present for Alba’s fans on the eve of Thanksgiving! Share Alba pictures with your friends, and the gift will be yours! Click to view details.
    2010-11-12T09:30:32+00:00
    "Me too!"
    I believe that some confusion may exist between "stealing focus" (where a window OTHER than the window which is presently most foreground, is the window receiving keystrokes), and what bugs me and many others in this thread:
    That windows can claim focus - bring themselves to the foreground - withOUT the user's request or permission.
    Microsoft & friends, how do we configure the Windows window manager so that no window may ever come to the front or get focus unless the user explicitly requests it to do so?
    Jay Libove, CISSP, CIPP, CIPP/IT, CISM
    2010-11-12T19:36:55+00:00
    I hope also for a solution for that nasty problem.
    Even when minimizing Firefox, Firefox reopens very often to 'present' some new content it has loaded...
