Applications stealing focus - reg key no longer fixes
2010-04-08T18:42:59+00:00
I want to prevent any applications from stealing focus in windows 7 (and Vista).  Tweakui used to modify the below Registry key to 0.  Then there was a key that affected the number of flashes a "want to steal focus" window would make in the taskbar.
ForegroundLockTimeout
HKEY_CURRENT_USER\Control Panel\Desktop
This reg key is apparently no longer working.  Focus stealing is a major problem, from canceling/oking window that pop-up, to getting virus's from IE windows.  Applications are still written to do this, including MS Office 2007.  If you are typing an email something can pop up and get the next key stroke.  I need to fix this.  Any ideas, or has Windows completely removed a needed feature.
tags: steal focus apps active regedit
2011-10-23T11:13:03+00:00
I solved the problem in this way:
I noticed that just before the focus was "stolen", the PC got "busy" for a second (beside the mouse appeared the small circle indicating the processor is working hard on sth).
So I started the Task Manager and gave a close look at the processes. I noticed that one process took over a relevat percentage of CPU usage exactly an instant before the focus was stolen from the task manager window.
Since it was a process that I don't need to be active all the time (sth about Vodafone Mobile connection, which I rarely use) I just stopped the process and then didn't allow the process to be started every time I turn on the PC. I did this last step using Piriform's free software  "CCleaner", but I'm sure you can find different tools for this...
This was enough to fix it ...
Hope this helped!
Bye!
166 additional answers
    2011-09-23T21:03:59+00:00
    Yes there is confusion, steeling focus may well be prevented in Win7 but there are plenty of legitimate ways that windows can 'CLAIM' focus, all are repeatable.
    For example, I will be writing an email and know that when I've finished I want to use Adobe InDesign. So I click the taskbar icon for InDesign and it starts loading. This is going to take a while so I go back to the email and keep typing. At some point InDesign finishes loading and steals focus from the email I'm writing.
    You can swap pretty much any program into this scenario.
    I know that for many users this feature is what they want. But for me it is annoying. The worst case is loading a program that has shortcut keys that do serious things without an undo. I'll be happily typing away and the new program steals focus, I hit a critical shortcut key without realising it. A pop-up appears and asks if I'm sure I want to do this un-reversable action. Before I have realised what is happening I have hit the spacebar, which of course actions the highlight 'YES' I'm sure I want to do this stupid thing and some important document gets trashed and I need to spend ages fixing it.
    Admittedly it is rare that this serious scenario occurs, but ALL these focus changing events are frustrating. I DO NOT WANT TO WASTE TIME WAITING FOR THINGS TO LOAD just because if I try and do something else it might mess things up when the focus changes without my permission. I want to multi-task, what is the point of having a PC that can have multiple applications running if you have to do tasks one at a time? When I am ready to attend to the event that an application has flagged I will attend to it, in the mean time I want to finish the other task that has MY FOCUS.
    I am happy for the application to flash in the task bar to inform me that it wants attention, I do not want it interupting me in the middle of a rant on a forum!
    I hope this clears up the misunderstanding some people here have, that we are moaning about something that doesn't happen or is rare.
    2011-09-24T00:44:08+00:00
    I honestly can't reproduce it.  Previously in this same thread I've posted pictures and video of me trying.
    I'm not saying it doesn't happen -- I'm saying that there must be a reason that we haven't discovered.  I wish I had a system image I could compare it to and scour the registry or DWM memory dumps to find out what is the difference.
    2011-09-24T07:51:40+00:00
    Yes - this happens for me too.
    Start Outlook, for example, and when it finally springs into life it steals your focus from wherever you are.
    Start a debug cycle in Visual Studio - one with a long build time - and then start writing an email. When the program has completed compiling it will launch and steal / claim your focus.
