Applications stealing focus - reg key no longer fixes
2010-04-08T18:42:59+00:00
I want to prevent any applications from stealing focus in windows 7 (and Vista).  Tweakui used to modify the below Registry key to 0.  Then there was a key that affected the number of flashes a "want to steal focus" window would make in the taskbar.
ForegroundLockTimeout
HKEY_CURRENT_USER\Control Panel\Desktop
This reg key is apparently no longer working.  Focus stealing is a major problem, from canceling/oking window that pop-up, to getting virus's from IE windows.  Applications are still written to do this, including MS Office 2007.  If you are typing an email something can pop up and get the next key stroke.  I need to fix this.  Any ideas, or has Windows completely removed a needed feature.
tags: steal focus apps active regedit
2011-10-23T11:13:03+00:00
I solved the problem in this way:
I noticed that just before the focus was "stolen", the PC got "busy" for a second (beside the mouse appeared the small circle indicating the processor is working hard on sth).
So I started the Task Manager and gave a close look at the processes. I noticed that one process took over a relevat percentage of CPU usage exactly an instant before the focus was stolen from the task manager window.
Since it was a process that I don't need to be active all the time (sth about Vodafone Mobile connection, which I rarely use) I just stopped the process and then didn't allow the process to be started every time I turn on the PC. I did this last step using Piriform's free software  "CCleaner", but I'm sure you can find different tools for this...
This was enough to fix it ...
Hope this helped!
Bye!
166 additional answers
    2011-07-31T16:44:55+00:00
    I did some more reading and I found a very enlightening link about the subject.
    http://blogs.msdn.com/b/oldnewthing/archive/2009/02/20/9435239.aspx
    Let me summarize; It's hopeless. :(
    Now on the flip side, if you are a Linux user, KDE will give you absolute nit picky control over focus behavior and WINE is coming along nicely.
  2. Deleted
    2011-08-07T17:27:04+00:00
    Focus stealing has been a huge problem in Windows for at least since Windows XP, and probably longer than that. The method to protect against focus stealing has never worked - Granted, a has worked with a few programs, but the majority of programs still steal focus. These programs include those built by Microsoft, such as Microsoft Visual Studio (All versions).
    It is clear that Microsoft doesn't intend on solving this issue, as this problem has existed for at least 10 years.
    As far as I can tell, the only way to fix this, would be to intercept the call to SetForegroundWindow (http://msdn.microsoft.com/en-us/library/ms633539(v=VS.85).aspx) to prevent the original functionality from being invoked. Unfortunately I have had very limited success in intercepting function calls, so if anybody has had any success in doing this, please let me know about it.
