Applications stealing focus - reg key no longer fixes
2010-04-08T18:42:59+00:00
I want to prevent any applications from stealing focus in windows 7 (and Vista).  Tweakui used to modify the below Registry key to 0.  Then there was a key that affected the number of flashes a "want to steal focus" window would make in the taskbar.
ForegroundLockTimeout
HKEY_CURRENT_USER\Control Panel\Desktop
This reg key is apparently no longer working.  Focus stealing is a major problem, from canceling/oking window that pop-up, to getting virus's from IE windows.  Applications are still written to do this, including MS Office 2007.  If you are typing an email something can pop up and get the next key stroke.  I need to fix this.  Any ideas, or has Windows completely removed a needed feature.
tags: steal focus apps active regedit
2011-10-23T11:13:03+00:00
I solved the problem in this way:
I noticed that just before the focus was "stolen", the PC got "busy" for a second (beside the mouse appeared the small circle indicating the processor is working hard on sth).
So I started the Task Manager and gave a close look at the processes. I noticed that one process took over a relevat percentage of CPU usage exactly an instant before the focus was stolen from the task manager window.
Since it was a process that I don't need to be active all the time (sth about Vodafone Mobile connection, which I rarely use) I just stopped the process and then didn't allow the process to be started every time I turn on the PC. I did this last step using Piriform's free software  "CCleaner", but I'm sure you can find different tools for this...
This was enough to fix it ...
Hope this helped!
Bye!
166 additional answers
    2011-06-06T14:55:29+00:00
    Status update:
    On the new 'clean' user profile the focus issue came back partially:
    1.- When using Firefox 4.01 with more than 1 tab open. So I did the Safe Mode test, issuue persist. Also removed all extensions and plugings (except Flash, Java, and Xmarks) , not only via the browser options but manually on the User's AppData\Roaming\Mozilla\Firefox\Profiles... folder deleting the extension.* and pluginreg.dat. With Firefox 'cleaned' the issuue still persist. I also moved the tabs from the top as it looked like the window title bar and the tabs on top were fighting over the same real state (Right click on the toolbar, uncheck 'Tabs on top") and I did notice a big improvement, but the issue still remains. Now looks like the tabs fighting for the focus when something happens.
    2.- When the Skype window is open. Less anoying as I normally open Skype as required and exit completely when done.
    Outlook (my worst focus loss nightmare) is behaving like a Champ, that is when Firefox is not running. I will uninstall Firefox tonight, but  I'm stubborn enought to fight it some more today.
    Maybe Shawn or someone with a deeper knowledge of the guts can use this info.
    Regards!
    2011-06-26T15:13:01+00:00
      If you have a way to reliably reproduce the behavior it will be helpful.
    Steps to reproduce:
    1. Using Windows 7 Home Premium SP1, start Windows Live Messenger (2011, Build 15.4.3508.1109), sign in, make sure it's in compact view, and move the window to the right side of the screen.
    2. Start Firefox (version 5.0), bring it up (not maximized) and move it's window off to the left side (so the messenger window is entirely visible).  Make sure the window focus is on Firefox.
    After a while (maybe about a minute?) messenger's ad system will grab the focus away from Firefox. I use the mouse wheel to scroll Firefox pages, so it is super noticeable when messenger grabs the focus, as the scrolling for Firefox stops working.  This happens even when the mouse is nowhere near the messenger window, so it's not stealing focus due to the mouse being over it.
    I'm sure this will happen with other applications other than Firefox, but that's usually when it's most noticeable for me.
    2011-06-26T17:13:14+00:00
    And here is another way - with only using MS software....
    Using IE6/7 or 8, kick off a large download. Then switch to another app (Word for example) and type stuff.
    As the download finishes IE will steal focus and show the "copying file" dialog...and if you are typing you may well press space which will cancel the copy/download.
