Applications stealing focus - reg key no longer fixes
2010-04-08T18:42:59+00:00
I want to prevent any applications from stealing focus in windows 7 (and Vista).  Tweakui used to modify the below Registry key to 0.  Then there was a key that affected the number of flashes a "want to steal focus" window would make in the taskbar.
ForegroundLockTimeout
HKEY_CURRENT_USER\Control Panel\Desktop
This reg key is apparently no longer working.  Focus stealing is a major problem, from canceling/oking window that pop-up, to getting virus's from IE windows.  Applications are still written to do this, including MS Office 2007.  If you are typing an email something can pop up and get the next key stroke.  I need to fix this.  Any ideas, or has Windows completely removed a needed feature.
tags: steal focus apps active regedit
2011-10-23T11:13:03+00:00
I solved the problem in this way:
I noticed that just before the focus was "stolen", the PC got "busy" for a second (beside the mouse appeared the small circle indicating the processor is working hard on sth).
So I started the Task Manager and gave a close look at the processes. I noticed that one process took over a relevat percentage of CPU usage exactly an instant before the focus was stolen from the task manager window.
Since it was a process that I don't need to be active all the time (sth about Vodafone Mobile connection, which I rarely use) I just stopped the process and then didn't allow the process to be started every time I turn on the PC. I did this last step using Piriform's free software  "CCleaner", but I'm sure you can find different tools for this...
This was enough to fix it ...
Hope this helped!
Bye!
166 additional answers
    2011-02-06T05:17:49+00:00
    Suggestions, please?
    2011-02-07T22:37:59+00:00
    If it was fine for about a year, I'd say that there was some change that caused it to start happening (makes sense, right?)
    So we need to determine what, exactly, is causing the issue.  Is it a system update, possibly replacing a DLL with a buggy version, an app install, a combination, or other factors.
    If we can find the pattern of what causes the behavior, we'll be a lot closer to a resolution.
    If this solves your issue, click the 'Propose as Answer' link below, and vote as helpful by clicking the green triangle to the lelft. Thanks!
    I think you summed it up pretty well what needs to be done.  Problem is, I can't find anything related to the problem other than running task manager minimized seems to prevent the behavior.  Awaiting some wonderful suggestions beyond everything I tried.
    2011-02-09T21:30:00+00:00
    I was hoping to hear something.
