network printer shows offline
2009-08-21T20:06:51+00:00
In windows vista my cable network printer shows offline now. Everything else is fine i can still go onto the internet etc. ??
2010-03-23T04:23:01+00:00
right click on (Network)Printer , choose Properties , go to Ports tab, choose Configure Port , then un-check SNMP Status Enable option,
I had same problem and this solution solved for me, hope this will help for u.
tks,
TZ
56 additional answers
    2013-05-07T14:38:35+00:00
    Had the same problem  on a terminal server and this did the trick.  Thank You
    2013-06-04T06:37:47+00:00
    Thanks, this did the trick, we have been having this issue for a while at work, I'm glad I found this post.
    2013-06-10T04:53:01+00:00
    Some times its quiet difficult to find out the problem. Trouble shooting takes time. It is due to one off the following reasons.
    Network cable unplug
    Drivers were outdated. and many other issues for more info read this article http://printer-offline.com/what-to-do-when-a-network-printer-goes-offline/
    2013-07-09T08:21:42+00:00
    Thanks brother,
    Your solution was perfect. You saved me a great deal. You keep up the good work and trust you will keep getting most of this kudos.
    Regards
