Vista won't boot - System restore/Startup repair can't fix
2009-02-23T21:29:36+00:00
Have Vista running on Dell Inspiron 1720. All of a sudden I can't start Windows. Startup Repair cant fix the problem and System restore can't seem to solve the problem either. Am starting to panic.
Startup Repair listed the following as the problem details but it leaves me clueless.
Problem Event Name:Startup repairV2
Problem Signature 01:  AutoFailure
Prob Sig 02:  6.0.6001.18000.6.0.6001.18000
Prob Sig 03:  6
Prob Sig 04:  786444
Prob Sig 05:  Corruptvolume
Prob Sig 06:  NoRootCause
Prob Sig 07:  0
Prob Sig 08:  2
Prob Sig 09:  WrpRepair
Prob Sig 10:  87
OS Version:  6.0.6001.2.1.0.256.1
Local ID:  1003
Have used Dell pre-boot checks and all physical systems seem fine so must be software. Can anyone help?
2009-02-24T04:30:46+00:00
Hello Buzbyb6,
Thank you for posting to the Microsoft Answers Forum.
I have some questions for you to help with troubleshooting your issue.
  • When trying to boot do you get a blue screen? If so, then try to get the error code number that comes up. That will give us more insight as to what could be causing your issue.
  • Can you boot into Safe Mode? Press F8 as Vista is starting up. then select Safe Mode.
Some of the things that could cause this issue would be a corrupt file system, bad Ram, or faulty hardware.
  • If you can get into safe mode. Run CHKDSK to fix the file system. Go to a command prompt and type chkdsk /r
  • Check the RAM using Memtest from a bootable floppy or CD. www.memtest.org
  • Check the HDD for bad sectors.
  • If its just a corrupted OS, backup your data and run Recovery to restore Windows to its factory state.
Please post again and let us know if your issue is resolved or if you need further assistance.
Sincerely,
Marilyn
49 additional answers
    2009-09-30T11:34:21+00:00
    I have the same issue all of a suddon my computer shut down now windows wont boot ,  wont restore , i cant go in safe mode, says there are no restore points,cant full restore cause it cant find back up files? im operating in a limited state and it just keeps wanting to run scan disk / repair but it stops and says vista cant fix  the problem?? My computer didnt come with a restore disk so now what?????????????
