Window 7 will can not Backup or let me do a system image backup.
2009-10-24T06:06:16+00:00
I have just upgraded to Windows 7, but when I try to do a complete backup or system backup, it fails.
I started to do a full backup to dvd, it took hours and stopped  at 84%,  I also tried to backup with system image, but this faild,  I tried to backup to an external drive 80GB drive and window said this wasn’t big enough.
Why cant I  backup Windows 7.
Thanks for any help
Windows for home | Previous Windows versions | Recovery and backup
64 additional answers
    2010-01-14T13:23:55+00:00
    As my Windows 7 Ultimate backup is 'not fit for purpose', instead I am using Microsoft approved Acronis True Image Home 2010.
    2010-01-19T04:20:03+00:00
    By any chance did you ever resolve your backup problem?  I just bought a Dell laptop and have the same issue.  Dell wants me to format my hard drive and re-load all of the programs.  I don't think that would help.  Microsoft will not provide support as the OS, Windows 7, is OEM and they say that the laptop manufacturer has responsibilty.
    Thanks, Lloyd
    2010-01-19T11:29:14+00:00
    2010-01-19T13:55:37+00:00
    Hello- an update.
    Still doesn't work. I have not tried the Acronis True Image solution yet, but that is my next step. I did a clean install and used a full version of Windows 7 professional 64 bit. All the drivers are up to date. The file system is NTFS on the external drive, and I formatted it several times to make sure it wasn't the issue. Never did work. I am not going to go through a clean instal over and over to solve this....too much work!
