error code 0x80780119 not enough disk space to create shadow copy
2009-11-21T23:17:58+00:00
When I try to create a system image I get an error that there is not enough disk space to create a shadow copy the error code is 0x80780119. I'm using Windows 7 Backup and restore.
2010-02-24T01:28:54+00:00
A Workaround Without Repartitioning:
When trying to make a system image of Windows 7, I got error 0x80780119.  After searching this thread (plus others), I found my 100 MB System Reserved partition had grown a large USN journal.  I assigned it drive letter F:.
Fsutil usn queryjournal F:
Then I ran this command to clear and disable the USN journal on my System Reserved partition:
fsutil usn deletejournal /N /D F:
This freed 48 MB.  The USN journal on my System Reserved partition remained disabled after a reboot, which I verified by re-running the query.  Subsequently, I was able to make a system image without error.
Look here for details on FSUtil: http://technet.microsoft.com/en-us/library/cc788042(WS.10).aspx
Mancer, MCITP-EA
2010-01-03T14:37:14+00:00
You should be able to find your answer here http://social.technet.microsoft.com/Forums/en-US/w7itproperf/thread/25deba76-464b-4a9d-9b32-a283bb6a88ce
MCSE, MCSA, MCDST [If this post helps to resolve your issue, please click the "Mark as Answer" or "Helpful" button at the top of this message. By marking a post as Answered, or Helpful you help others find the answer faster.]
41 additional answers
    2015-05-21T22:11:36+00:00
    I would try the utility as I don't think it matters if your PC is by Dell or not
    2015-05-21T22:39:26+00:00
    Thanks for your help Joe576.
    I have downloaded the utility as you have suggested and have opened it.  It does not show a partition named WINRETOOLS.  Does it exist in a home build Windows 7 Ultimate system? If so, then do I need to hunt for it?  If so, how do I use the utility tool to locate it?  It isn't obvious to me.
    2015-05-21T23:13:30+00:00
    Sorry but I'm not sure. I never had the problem on non Dell PC's so it appears that your issue may be caused by something. Else. The newer version 9 of the MiniTool Software has a link to their online manual and you might try that.
