Hi Paul,
Welcome to Microsoft Answers!
Where are you trying to take a backup?
Method 1:
You may check if you have enough disk space in the disk management.
1.
Click Start
2.
Right Click on Computer
3.
Choose Manage
4.
Click on Disk Management
Check if there is enough space in the disk for a complete PC backup.
Method 2:
You may try running a check disk and see if that helps.
1.
Open Computer by clicking the
Start button, and then clicking Computer.
2.
Right-click the drive that you want to check, and then click
Properties.
3.
Click the
Tools tab, and then, under Error-checking, click
Check now.
If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
To automatically repair problems with files and folders that the scan detects, select
‘Automatically fix file system errors’. Otherwise, the disk check will report problems but not fix them.
To perform a thorough check, select
Scan for and attempt recovery of bad sectors. This scan attempts to find and repair physical errors on the drive itself, and it can take much longer to complete.
To check for both file errors and physical errors, select both
Automatically fix file system errors and Scan for and attempt recovery of bad sectors.
4.
Click
Start.
Depending on the size of your drive, this might take several minutes. For best results, don't use your computer
for any other tasks while it is checking for errors.
For more details follow the link.
Check a drive for errors
http://windows.microsoft.com/en-US/windows7/Check-a-drive-for-errors
Also refer to the below mentioned links which talk about the same issue.
http://social.answers.microsoft.com/Forums/en-US/w7performance/thread/e3d30717-5e1a-47ad-a774-efe2afa59b7c
http://social.technet.microsoft.com/Forums/en-US/w7itprogeneral/thread/fce6950d-c06d-4dd0-a850-67022db4fe04/
http://social.technet.microsoft.com/Forums/en/w7itprogeneral/thread/894f0901-811d-4270-955e-2962c2a4bc4d
Hope this information is useful.
Amrita M
