Managing tabs, address bar, and search settings in Edge on Windows 11
I've already disabled Copilot in the sidebar. I've toggled off "Chat response on result page" in the search settings. I want the Copilot AI disabled from the search result page, preventing automatic chatboxes on searches, and not activating when scrolling to the top of the results page.
I Use Chrime for everything short cut's links etc
Speed Dial [FVD] - New Tab Page, 3D, Sync...
81.7.1
New Tab Page Replacement with 3D Speed Dial and predefined images, sync and organize your bookmarks, groups, and most visited
I agree Microsoft has to learn a thing or to they didn't Pay for Our computer the manifacture web sites have there OWN DRIVERS FIRM WARE r\etc I got to them not Out dated we think you might like the windows arternities .
81.7.1
aand the don't Imject Bloatware as Microsoft does that slows down you're you don't need servires the index turned off and unlinked we have ways around this we don't need all this garbage that Hoggs up resoreces on are computer if Microsoft wan't to come with a windows light with out all the bloat ware then listen to the people not take matter into there had we can always use another operating system with out windows Injected blaotwear.you grt you're system resorces bat that run in the back ground that cloud hogg up system resorces whats the sence paying over $2.000 to $4.000 ot to have Microsft SPY on you yes did they think where stupid lolol to have slow down youre system that you'res Not there/s they end Like meta back In us coongresss and restrictions put on them .Software regulations Including AI MUST fully regulated right it's out of Control.
I think that most of you are misinterpreting A. User's problem. The problem is turning off Copilot in BING SEARCH, not Microsoft Edge. Turning off Copilot in Edge is easily done. Turning off Copilot in Bing Search is so far impossible. You will need to change the default search engine in Edge.
Yes, it's really a pain when your "Copilot" turns out to be a Hijacker instead!! Copilot totally ruined the Edge browser. I am switching back to Google as my default search engine and start page and not using Bing anymore. That's a shame! I enjoyed the Bing search engine up until Copilot was introduced.
I completely uninstalled Copilot in Windows 11 Pro using Revo Uninstaller Pro and no signs of Copilot appear anywhere on my machine & Windows settings or Edge browser.... right up until I open Bing search and then Copilot acts like a hijacker. Enough is enough!!
Microsoft doesn't care!
To change your default search engine in Microsoft Edge:
I have already done all that, but each time I start Edge again, Copilot still wants to have it's say. And Copilot response on result page is still turned on again after turning it off. Desperation answers are needed. So it is Bing doing it?
To what I understand from what I have read from other websites is that Copilot is embedded in the Bing Search Box, and Microsoft are not worrying about fixing the problem of allowing Copilot to be totally disabled or removed from the Bing Search Box.
I changed my default search engine under "Manage search engines" to Google using the Address Bar at the top, I now don't use the Bing Search Box. But what I don't understand is that you first must insert a minimum of a character in the Address Bar and press Enter before the Google Search Box displays directly under the Address Bar. It would be nice if the Google Search Box or at least a box to tick for the Google Search Box display, instead of using the Address Bar first.
In the section where you can change the Search Engine to Google or any other search engine, it shows Bing (Recommended). I think because Bing is Recommended that prevents Copilot from being disabled or removed from the Bing Search Box.
My frustrations with Copilot have eased knowing I can now use Google Search Engine via the Address Bar without the need to use the Bing Search Box.
