How to completely remove Copilot from Edge?
Reported
2024-02-27T17:03:42+00:00
I've already disabled Copilot in the sidebar. I've toggled off "Chat response on result page" in the search settings. I want the Copilot AI disabled from the search result page, preventing automatic chatboxes on searches, and not activating when scrolling to the top of the results page.
Microsoft Edge | Tabs, address bar, and search | Windows 11
    2024-06-13T16:54:43+00:00
    Yes. But when I tell you how, it will not be long before Microsoft does something about it.
    Run PowerShell in Admin mode the run the below command.
    Get-AppxPackage *Copilot* | Remove-AppxPackage
    Reboot.
    You will probably have to do this after each set of patches.
    2024-06-29T18:09:30+00:00
    This is completely worthless and ineffective.
    COPILOT IS A WASTE OF TIME AND I HAVE NOT BEEN ABLE TO REMOVE IT..
    DESIGNED BY AN IDIOT.
    2024-07-10T04:21:57+00:00
    I've tried everything.
    The dam thing is off yet still it shows up results on the dam page - pissed off with Edge - time to delete and find a new browser.🤬
    2024-07-10T08:05:13+00:00
    Good Luck with that Janette. You know it will get reinstalled during a patch Tuesday session as Microshaft will just decide it HAS to have it loaded.
    They've gone from providing computing tools we need/want to mandating stuff we don't use/don't want.
    Eventually they may start charging us to remove the garbage - a bit like PrimeFlix now charging to remove adverts - but for now they are content to flex their dominance over our lifestyle without a damn about consumer choice.
    2024-07-15T20:49:44+00:00
    i tried several times and the side bar is still there.
