Microsoft Edge closes immediately upon opening. I've tried many fixes none work.
2023-08-15T11:52:24+00:00
Yesterday, I wanted to clean up my favorites in Edge (remove duplicates, remove obsolete links). In the midst of this, Edge closed without warning or error message. When I restarted Edge, it closed immediately. I could not select the three dots in the top right. It closed too quickly.
I found several possible solutions including tools in the Settings/Apps menu, other fixes involving removing and then reinstituting the %LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe directory
None of these fixes worked.
When I restart Edge, it closes immediately.
How can I get it to work properly?
Microsoft Edge | Browser crashes or stops working | Windows 10
  1. Deleted
    2024-03-07T03:57:37+00:00
    So,
    Before it closes, grab the window and drag it for a second (like if moving it to another screen). That stopped it from closing.
                  -\_-
  3. Deleted
    2024-03-29T04:40:41+00:00
    same issue after deleting
    2024-03-29T04:45:23+00:00
    Good thanks, it's working now
