Troubleshooting browser crashes or performance issues on Windows 10
Yesterday, I wanted to clean up my favorites in Edge (remove duplicates, remove obsolete links). In the midst of this, Edge closed without warning or error message. When I restarted Edge, it closed immediately. I could not select the three dots in the top right. It closed too quickly.
I found several possible solutions including tools in the Settings/Apps menu, other fixes involving removing and then reinstituting the %LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe directory
None of these fixes worked.
When I restart Edge, it closes immediately.
How can I get it to work properly?
You are fantastic! I can't thank you enough for the time you put into this to help me and I hope others.
This corrected my problem and your video was great and very understandable and the address you gave me I was able to delete and find that extension folder!
thank you again!
This video is fantastic and it worked! Thank you!
Glad it helped!
It didnt work
I am also am having this issue with edge
