Troubleshooting browser crashes or performance issues on Windows 10
Yesterday, I wanted to clean up my favorites in Edge (remove duplicates, remove obsolete links). In the midst of this, Edge closed without warning or error message. When I restarted Edge, it closed immediately. I could not select the three dots in the top right. It closed too quickly.
I found several possible solutions including tools in the Settings/Apps menu, other fixes involving removing and then reinstituting the %LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe directory
None of these fixes worked.
When I restart Edge, it closes immediately.
How can I get it to work properly?
I followed your instructions, but I don't see "Apps & features" I only see "optional features" and don't see microsoft edge there. Please help
Worked like a charm. Edge Started right up.
When I went back into that extensions folder the file I had I had deleted dated 11-07-23 had reestablished so I deleted the copy I made.
Client will be happy a reload of computer is not required!
Thanks for saving us a lot of time.
I could not find the path C:\Users\username\AppData\Local\Microsoft\Edge\User Data\Default\Sync Data\LevelDB
I got to users\username could not find appdata
Microsoft Edge still not working
"AppData" is a hidden folder - to see it, either go to "View" ... "Show" ... "Hidden Items" which will permanently fow all hidden folders and files, or instead type "%localappdata%" (without the quotes) in the address bar.
Did you try my steps I posted earlier - seems to work for most people.
In the address bar for file explorer, go to
%localappdata%\Microsoft\Edge\User Data\Default\Extensions
Sort folder by "Date Modified"
If you see one that has been modified recently - for me, last night - it may be the cause. The names of these folders won't make any sense, and I couldn't tell you what the extension was, however for me I took a copy of the following folder then deleted it. Edge restarted ok
cjpijioncddkancpiedagilpojbgmoni
After starting edge, the above folder was re-instated.
ALWAYS TAKE A COPY of the folder so you can reinstate it if you need.
I attempted all of these steps - multiple times - without any result, both with and without restarting as well.
Also updated system.
There were no Edge processes running and I verified that the files were deleted. As soon as I tried Edge again, the files were recreated, but Edge still closed immediately.
