Troubleshooting browser crashes or performance issues on Windows 10
Yesterday, I wanted to clean up my favorites in Edge (remove duplicates, remove obsolete links). In the midst of this, Edge closed without warning or error message. When I restarted Edge, it closed immediately. I could not select the three dots in the top right. It closed too quickly.
I found several possible solutions including tools in the Settings/Apps menu, other fixes involving removing and then reinstituting the %LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe directory
None of these fixes worked.
When I restart Edge, it closes immediately.
How can I get it to work properly?
Thank you SOOOOO MUCH! Also, why would this folder cause the app to automatically close? If Microsoft pushed the update and (seemingly everyone) had the same issue with it, wouldn't they post another update right away to resolve it?
This worked for me.
My hero. u a real one.
Appdata is a hidden folder. There are two ways to get around this.
In file explorer, do one of the following
Hope this helps.
This solution worked for me too! Many thanks, btw the distorters was a .json file
