Microsoft Edge closes immediately upon opening. I've tried many fixes none work.
2023-08-15T11:52:24+00:00
Yesterday, I wanted to clean up my favorites in Edge (remove duplicates, remove obsolete links). In the midst of this, Edge closed without warning or error message. When I restarted Edge, it closed immediately. I could not select the three dots in the top right. It closed too quickly.
I found several possible solutions including tools in the Settings/Apps menu, other fixes involving removing and then reinstituting the %LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe directory
None of these fixes worked.
When I restart Edge, it closes immediately.
How can I get it to work properly?
Microsoft Edge | Browser crashes or stops working | Windows 10
    2024-04-16T08:32:45+00:00
    Same here, I seem to be renaming once a day at the moment and it's frustrating. I tried deleting some of the pertinent folders in "User Data" to see if I could find the rogue one but alas no. If this doesn't get fixed soon I will be forced to use something else.
    2024-04-16T06:10:31+00:00
    I've got 4 "User Data OLD" folders now, because it still keeps happening, randomly. So until there's a permanent fix, I guess I'll just keep doing what I'm doing. UPDATE: I made a backup copy of the User Data folder while it was still working. Tried renaming the User Data folder to OLD and copied the backup to the original folder, but that didn't work.
    2024-04-16T05:53:27+00:00
    A million thanks, you saved me at least those 6 hours that you spent looking for an answer, and I truly appreciate it.
    2024-04-14T08:53:50+00:00
    Worked for me. A week later, it happened again. Renamed again. Set up options, again. We'll see how long it works this time.
    2024-04-13T15:10:51+00:00
    This was the fix for me. Thank you so much - I was going crazy searching for a solution.
