Troubleshooting browser crashes or performance issues on Windows 10
Yesterday, I wanted to clean up my favorites in Edge (remove duplicates, remove obsolete links). In the midst of this, Edge closed without warning or error message. When I restarted Edge, it closed immediately. I could not select the three dots in the top right. It closed too quickly.
I found several possible solutions including tools in the Settings/Apps menu, other fixes involving removing and then reinstituting the %LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe directory
None of these fixes worked.
When I restart Edge, it closes immediately.
How can I get it to work properly?
I had this issue arise yesterday. I conducted a system restore from two days ago, and that fixed the issue. My other browser Google Chrome, still has this problem.
Norton antivirus’s browser has yet to have this problem ?
Hi GeorgeSmuga = I had this problem + what seems to resolve it now is that I had another search engine as my default : now I have set my Microsoft Edge as the default search engine it opens up OK. I assume the problem has arisen from the latest Microsoft Update and done to protect their priority? Trust this works for you.
Worked a charm. Thanks.
This is affecting a lot of users. Surprised Microsoft hasn't picked it up straight away.
To be able to see "appdata" - which is a hidden folder, you can go into File Explorer, then click on "View" ... "Show" ... "Hidden Items"
For the other option you have, you can use the above explanation to show "Appdata", then navigate to "Local" and work from there.
Hope that helps.
Worth mentioning that you should always be cautious if you are not familiar with the use of "appdata" in windows - and I would strongly suggest you take a copy of any folder that you are planning on deleting or modifying the contents of so you can re-instate it if needed.
Worked like a charm; Thanks....
