Translation process does not work
2023-06-29T17:40:50+00:00
Whenever I try to translate a web page in Edge I get the following message "Translation failed".
I've tried resetting settings, clearing cookies, etc...
What else can I do?
Microsoft Edge | Browser crashes or stops working | iOS
    2023-06-29T18:22:41+00:00
    Hello Johndavies_799,my name is Luiz Cruz independent consultant and I'm here to help you;
    I understand Edge translation is not working on your Iphone;
    In that case I suggest you try the following;
    Launch Edge;
    Click on the three bars (upper right corner of the screen) and access Settings;
    Go to General > Microsoft Translator;
    Enable the "Translate pages" option;
    Check the languages ​​in the list, if the option is set to "Never translate", click on the language and enable the option "Offer for Translation";
    You can add more languages ​​by clicking on "Add Language...";
    Close Edge and launch again;
    Check if the pages are translated now;
    Hope this helps, see you soon!
