Edge keeps running in the Background
2023-10-23T13:57:28+00:00
Hi All,
I know ... this is old and usually easy ... turn off "Startup Boost" and "Continue running background apps ..."
I have those off and it always worked they way it supposed to.
All of a sudden Edge keeps running.
Indication for still running comes from Ccleaner, which removes all trackers. All of a sudden I get the message:
(paraphrased) Ccleaner can't clean because Edge is still running ... needs to be forced shut down"
In Task manager I also still see 11 Edge processes going even though Edge is shut off.
Again ... "Startup Boost" and "Background Apps ..." are unchecked in settings.
Any suggestions?
I repaired Edge already and nothing changed. Its updated.
PS: I checked in another machine (Win10), same Edge version ... no problems here ... all Edge processes in Task Manager disappear
when shutting Edge down.
Microsoft Edge | Other | Windows 11
  1. Deleted
  2. Deleted
    2023-12-02T13:14:57+00:00
    This fix it does not work at all. Tried it and guess what? Edge still runs in the background after closing it. Microsoft needs to fix this error with Edge
    2023-12-02T16:39:17+00:00
    Thanks for the post.
    Unfortunately, like any other change in the Edge settings that attempt to resolve this issue, it has only a temporary impact.
    Sure, when you make the change and close Edge, the processes stop.
    But reboot, use Edge to navigate the internet and then close it ... processes run forever just like before.
    Also, disabling hardware acceleration prevents Edge from using my NVIDIA GPU so even if it did work, it would not help my particular situation.
  5. Deleted
