Other issues or features related to Microsoft Edge on Windows 11
Hi All,
I know ... this is old and usually easy ... turn off "Startup Boost" and "Continue running background apps ..."
I have those off and it always worked they way it supposed to.
All of a sudden Edge keeps running.
Indication for still running comes from Ccleaner, which removes all trackers. All of a sudden I get the message:
(paraphrased) Ccleaner can't clean because Edge is still running ... needs to be forced shut down"
In Task manager I also still see 11 Edge processes going even though Edge is shut off.
Again ... "Startup Boost" and "Background Apps ..." are unchecked in settings.
Any suggestions?
I repaired Edge already and nothing changed. Its updated.
PS: I checked in another machine (Win10), same Edge version ... no problems here ... all Edge processes in Task Manager disappear
when shutting Edge down.
That fix worked for me. Edge is closing all the process after I applied the fix.
After rebooting few times?
Good for you,
but I don't have / never had the issue on my Win10 machine ... only Win11.
Good for you,
Klaus, maybe you can review your Win 10 Edge related settings and find what's working for you. I have one Win11 machine and 3 Win10 machines, and they all behave exactly the same with edge running in the background after closing. I'd be curious to see what's working so well for your Win10 machine.
Hey Folks! I Just clean installed Windows 11 Home, deleted the inbuilt Microsoft edge and all its related files and installed Microsoft Edge Beta.
I don't to seem to have this problem anymore.
